Newbie with 30.0 EK-15R/1933D
this thread has 14 replies and has been viewed 526 times
Old 11-08-2017, 09:44:35 AM
ChapinGuy ChapinGuy is offline
Default Newbie with 30.0 EK-15R/1933D
Hello all ... I'm a newbie and just purchased this unit. I know it is currently setup for NG at 208V-3P and runs perfectly as such. It was highly maintained by the company I work for since new. It has very low loaded hours. It is in excellent condition with only typical oil leaks at the front main seal and valve cover gasket It is a little dirty now but was very clean prior to recent construction in the area. The serial number is 0571300010.
I want to convert to LPG and 120/240-1P. As I learn from info found here:
The unit is a 1957 model.
It will easily retap to 120/240-1P - assuming I can locate manuals/instructions.
The NG to LPG conversion appears to be a simple matter of retuning the mixer.
If any of that is wrong, please correct me.
QUESTION - The original transfer switch is available. Should I pay to have it removed/bypassed (~$250) for my use or should I just buy a new modern TS?
If you have manuals I will greatly appreciate any and all info.
GREAT SITE HERE GUYS!!! THANKS!
Old 11-08-2017, 09:50:05 AM
Default Re: Newbie with 30.0 EK-15R/1933D
Buy a new switch, if the original is as old as the set is.
Old 11-08-2017, 10:44:44 AM
Was made 5 of 71. Some of the 15r voltage code sets will drop to 20 kw on single phase unless it's extended stack
Old 11-08-2017, 10:44:59 AM
Kevin K Kevin K is offline
The serial number(0571300010) shows your generator was built in May (05) of 1971 (71).
Go to the Twinslan site and download the manuals: http://www.twinslan.net/~n0nas/manuals/onan/
928-0120 Operator
900-0150 generator Service
928-0220 Parts
T-105 Gaseous service manual
Check in the OEM Engine manuals folder for an engine service manual.
I'm attaching the factory production order and wiring diagrams.
Good luck.
The Following 5 Users Say Thank You to Kevin K For This Post:
Old 11-08-2017, 02:06:13 PM
Mac Sine Mac Sine is offline
If the engine is equipped with an Impco carburetor, you will need to install a negative-feed (demand) regulator upstream of the carburetor to run LP-Gas. A "standard" Impco carburetor handling LP-Gas (Propane) fuel requires a negative 1.5-inch water column gas inlet pressure (a vacuum). Natural gas, in contrast, is fed to the Impco carburetor at positive 5 inches water column.
The Following 2 Users Say Thank You to Mac Sine For This Post:
Old 11-08-2017, 10:28:40 PM
Attached should be pictures of the gas supply system. It appears to me to be a gas shutoff, maybe a regulator and or course a carburetor. Is this gear comparable with LPG.
Old 11-08-2017, 11:00:03 PM
Big thanks!!
Old 11-09-2017, 07:53:27 AM
Huh?????
I would like for you to elaborate some on the information you posted above. I would like to find out more about "negative feed" regulators.
The Following User Says Thank You to Max Thompson For This Post:
Old 11-09-2017, 01:13:50 PM
grif grif is offline
Originally Posted by Max Thompson View Post
Huh?????
This needs a bit more looking. I think he's mistaking or misstated the vacuum signal from the engine to start the fuel flow on gaseous regulators with the inlet pressure to the demand regulator.
Old 11-09-2017, 02:10:03 PM
ChapinGuy - The "Imp" (or Maxitrol) regulator shown in your picture three is what you need to change from natural gas configuration to propane gas configuration. Your "Imp" regulator is installed with the spring tower pointing down toward the ground. For natural gas operation, the spring inside the tower is adjusted to provide a nominal 5 inch water column positive pressure at the carburetor gas inlet. For propane gas operation you unscrew the cap on the tower and remove the spring from the tower. This causes the "Imp" to function as a negative-feed regulator and it will yield a nominal 1 inch water column negative (vacuum) pressure at the carburetor gas inlet. The "Imp" has to be installed with the spring tower pointing down to do this.
Max - A negative feed regulator is a demand regulator. It does not allow gas to flow to the carburetor until a vacuum signal is applied on the outlet of the regulator. When the engine is running the fuel gas pressure to the carburetor is below atmospheric pressure, therefore, a negative pressure. The well known Garretson KN is another example of a negative feed regulator. The nominal setpoint on the KN is negative one-half inch water column.
The difference between the Impco and Garretson regulator settings relate to the respective carburetor designs. The KN is applied with a venturi type carburetor, while the Impco carburetors are an air valve design. The vacuum signal derived by a venturi carburetor is relatively weak, compared to the vacuum signal derived by an air valve carburetor.
Do not confuse a vacuum-operated fuel lock device with a negative feed regulator. They are not the same. A vacuum fuel lock is operated by intake manifold vacuum. A demand regulator is responding to carburetor venturi vacuum. These two vacuum signals are very different from one another.
The Following User Says Thank You to Mac Sine For This Post:
Newbie wildwind Smokstak Forums Meet and Greet 2 06-19-2014 12:26:03 AM
Newbie from NC Crankin Smokstak Forums Meet and Greet 5 03-09-2014 09:56:56 AM
Just another newbie Cut4fun Smokstak Forums Meet and Greet 1 07-24-2010 11:18:54 PM
Newbie here....could use some help, please. Jim Steere Onan Generators 4 12-01-2008 08:59:24 PM
Need help: Newbie pcrmike Onan Generators 12 11-06-2008 01:23:35 AM
