Onan 4BGEF J30981E Need Production Order and Wiring Diagram
this thread has 15 replies and has been viewed 345 times
Old 11-09-2017, 06:35:21 PM
Bill Aggenbach Bill Aggenbach is offline
Default Onan 4BGEF J30981E Need Production Order and Wiring Diagram
Ser No. D880112365
Just acquired this for a friend of mine. Need to test and make run.
Any help would be much appreciated.
Bill
Old 11-09-2017, 06:53:39 PM
len k len k is offline
Default Re: ONAN 4BGEF J30981E Need Production Order and Wiring Diagram
You have a BGE spec E
Manual numbers and link to them
BGE spec f-k---NHE-spec e-k--EMERALD PLUS--SERVICE--(9-94)--- 965-0528.pdf .... don't think they printed manual for spec E, last one was for spec a-c
BGE (A-E)---BGEL (B-D) --PARTS---965-0232 Emerald I.pdf
http://www.twinslan.net/~n0nas/manuals/onan/
What's it's problems , no AC??
If not making AC unplug AC voltage reg and measure rotor ohms thru slip rings, should be 20.25-24.75 ohms. And not grounded.
If that is good I hot wire engine to run , with reg unplugged, apply 12VDC ( car bat) to brushes. Should make 40-50VAC out the T windings , 55-60 out the Q windings.
The Following 3 Users Say Thank You to len k For This Post:
Old 11-09-2017, 07:26:10 PM
MBB MBB is offline
Can you post a picture of the model number? That doesnt look right?
Old 11-09-2017, 08:10:07 PM
Len
Just acquired. Generator mounted on cart with wheels. I have to put a battery in it and clean slip rings (120 ohms rotor resistance). Spec E still has a transformer in it. Previous owner have reconnected the output to 120/240 and added a low voltage fuse holder for one leg and kept original CB for other hot leg (breaker now has only 1/2 the current). looks like housing can hold 2 breakers. Will be looking for some of these. After cleaning slip rings I will test first before spending money and time on it.
Bill
Old 11-09-2017, 08:19:49 PM
Attached is picture of model tag
Old 11-09-2017, 09:10:58 PM
MBB MBB is offline
OK here is the build sheet and the wiring diagram.
The model number (FJ) designates the new voltage code but the build sheet is the old codes. Can get confusing.
The Following 4 Users Say Thank You to MBB For This Post:
Old 11-09-2017, 09:43:27 PM
Thank you for the fast reply. Having a resource like makes it a lot easier to work on this equipment.
Old 11-09-2017, 09:46:26 PM
MBB MBB is offline
No problem. Were you able to find the manuals?
Old 11-10-2017, 12:02:21 AM
Originally Posted by Bill Aggenbach View Post
slip rings (120 ohms rotor resistance). Spec E still has a transformer in it. l
Very odd I could swear only spec A,B, C had ~ 8inch current transformer by the starter for voltage boosting under load.
Odd I thought rotor ohms were closer to 17 (have to read manual) , not 120 ohms. Maybe slip rings need cleaning. Try cleaning slip rings with schotchbrite pad.
Can you post pics of the gen and transformer.
Old 11-10-2017, 05:08:43 PM
MBB: Yes I found manuals. I am using the 965-0530 service manual since it uses a transformer for AC voltage regulation.
Len: I have attached a picture of transformer.
Thanks for the interest.
Bill
Onan 4BGEF J30981E, need Service Manual Bill Aggenbach Onan Generators 6 03-19-2017 07:32:47 PM
Onan 7.5JB Production Order Build Sheet Jim McIntyre Onan Generators 12 03-25-2015 08:29:31 PM
Onan Production Order Question BILL49 Onan Generators 23 12-08-2013 04:48:25 PM
Onan unit production order sheets Billy J Shafer Onan Generators 14 01-22-2011 09:42:28 PM
Onan 10 JC Info / Production order wanted Ted_Cool Onan Generators 2 11-06-2009 12:11:30 PM
