Rotating Diodes Checking
this thread has 32 replies and has been viewed 1216 times
Old 11-09-2017, 09:23:08 PM
EnginePat EnginePat is offline
Smile Magniciter Diodes Checking
I was looking at a onan 12mdjc that the owner claims the rotating diodes are bad in it , he said a friend checked them and that's what's wrong with the machine. Could I please get schooled on the proper checking procedure.
MODEL 12MDJC-3R/2268R
SPEC 0968061905
120/240 1 PHASE 50 AMP
06SX1N3B
12JC33N4C
Pat
5GO 3/RA
7.5 jb's x3
Old 11-09-2017, 09:45:02 PM
Jim McIntyre's Avatar
Default Re: Rotating diodes checking
This is a magniciter set, right? No rotating diodes in it.
Old 11-09-2017, 10:07:13 PM
BigBlockChev's Avatar
If that is the set in your post then I'm with Jim, if it is a different one let us know. Rotating diodes are a bit of a pain to check. They are covered in the YD gen end manual, but a certain amount of disassembly is required. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
Old 11-09-2017, 10:11:30 PM
Default Re: Rotating diodes checking (magniciter )
The Owner of the set said the diodes that were under the cover of the bell end were bad. I asumed they were the rotating diodes. Are there diodes in a magniciter end?
This is the set they may be in.
Pat
5GO 3/RA
7.5 jb's x3
Old 11-09-2017, 10:48:33 PM
Yes there are diodes under the endbell on a magneciter set, they are not rotating diodes , they can go and are not hard to replace , nor are they very expensive. There is a good thread in the stickys on magneciter theory and troubleshooting. It is long but enlightening. Cheers Dan
https://www.smokstak.com/forum/showthread.php?t=45741
The Following 3 Users Say Thank You to BigBlockChev For This Post:
Old 11-09-2017, 10:50:12 PM
Default diodes checking (magniciter )
Thanks Dan!
Pat
5GO 3/RA
7.5 jb's x3
Old 11-09-2017, 10:57:03 PM
Vanman Vanman is offline
And make sure that you take a good look at those saturable reactors. Make sure they're a nice tan color and not burned. Seller could be trying to pass off bad reactors as bad diodes.
Old 11-09-2017, 10:59:45 PM
Default Re: diodes checking (magniciter )
Right tan color good! Black ng!
Pat
5GO 3/RA
7.5 jb's x3
Old 11-10-2017, 01:12:34 AM
Default Re: Rotating Diodes Checking
REALLY REALLY simple to toss the magnecitor regulator and pop in a Power-Tronics unit. Works quite well. Assuming the rest of the set is OK I wouldn't worry much about the magnecitor being bad.
The Following User Says Thank You to pegasuspinto For This Post:
Old 11-10-2017, 02:27:22 AM
You could do that, but you would be replacing a few rugged possible points of failure with what, hundreds? thousands? Of delicate points of failure. Better to just buy a YD generator equipped set in the first place, and keep a few spare regulators on hand.
What happens if you have a blown rotating diode BigBlockChev Onan Generators 6 07-19-2015 08:36:59 PM
Rotating Throttle Repair? GreasyIron Steam Stationary Engines, Traction Engines, Steam Boats 22 09-23-2014 11:27:59 AM
Wisconsin VF4 rotating assembly ? GrumpyBobby Wisconsin Engines 4 05-03-2013 09:26:30 AM
MEP-16A Rotating Diode? K D Redd Military MEP and Aircraft Gen-Sets 3 08-19-2008 12:19:28 AM
