Onan MDJE wiring question...
this thread has 1 replies and has been viewed 229 times
Old 11-11-2017, 02:11:27 AM
NomadAU NomadAU is offline
Default Onan MDJE wiring question...
Hi,
I think I know the answer to this question, but I thought I'd check anyhow...
The exciter stator has a couple of wires that need to be routed to the control box. I can't remember how they were routed when I dismantled the genset, but I'm guessing that they were routed through one of the (many) openings that are around the outside of the main stator. The only other alternative I can think of is that they are routed through the vents of the exciter cover and then to the control box. Can anyone confirm that they get routed through the outside of the main stator?
The attached pic shows the wires from the exciter stator being lead back towards the main stator, and the main stator with the many through holes around its circumference.
Cheers,
Mike
Old 11-11-2017, 05:01:25 AM
BigBlockChev's Avatar
Default Re: Onan MDJE wiring question...
Exciter wiring is threaded through the stator near the top between sections. Normally there is no reason to remove it when taking off the stator. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
Onan MDJE wiring&parts W Wier Onan Generators 3 07-21-2011 04:27:33 PM
Onan MDJE Fuel Injector Question robertinmaine Onan Generators 5 07-15-2011 10:01:44 AM
1st time post, Question on Onan MDJE yachtgilana Onan Generators 24 03-11-2010 03:11:07 PM
Onan 7.5 MDJE intake question Nazrat Onan Generators 1 06-24-2008 12:15:10 AM
Need wiring diagram for MDJE ntjock Onan Generators 3 09-23-2005 12:09:29 PM
