4C Combustion Chamber and Carburetor Cleaner
this thread has 7 replies and has been viewed 1316 times
Old 11-11-2017, 01:31:04 PM
Surfinhurf Surfinhurf is offline
Default 4C Combustion Chamber and Carburetor Cleaner
Anybody use this stuff?
Old 11-11-2017, 04:23:08 PM
Newoldstock Newoldstock is offline
Default Re: 4C Combustion Chamber and Carburetor Cleaner
I tried a lot of things and not many worked as advertised.
Water works, but you have to use a lot of it and you have to use it for a long time to clean an engine.
It has the potential to do more harm than good sometimes.
A chemical company in Montreal made some stuff called CV-100 you mixed in your fuel it worked too ( after miles of driving ), but it also clogged all your filters and parts as it cleaned everything and it worked so well cleaning the fuel systems that today I am scared to think of what might be in it...
MY GOD it cleaned things, even removed the paint from your fender.
The inside of diesel engines were shockingly clean after a few hundred miles of it.
Seems to me your fuel economy improved too.
And it turned your nail bed a funny green colour and dried out your skin real bad if you got it on your fingers...
Loctite gasket/paint remover works.
But you have to pull your head off after you spray it in the combustion chamber and let it soak overnight.
Then the carbon come off like old paint... exposed to paint remover....
Nothing I have seen you pour into a running engine seems to do much.
At least not with one treatment, but non of it seems to do any harm....
Anything that does work well comes with risks.
Old 11-11-2017, 05:12:13 PM
consolenut consolenut is offline
there is the xyl*** (fill in the blank) in the fuel. Boosts octane and cleans exceptionally well. but don't want to be around the exhaust pipe when you do as its toxic to humans the gases it puts in exhaust. Instant casket!
Old 11-11-2017, 07:15:05 PM
JohnnyC JohnnyC is offline
I did a thread on cleaning combustion chamber using just about all products recommended and some never thought of including human piss. None cleaned better than removing the head and doing a good old fashion cleaning using elbow grease.
https://www.smokstak.com/forum/showp...6&postcount=85
https://www.smokstak.com/forum/showthread.php?t=157353
JohnnyC
New Jersey
Old 11-11-2017, 08:17:40 PM
David C David C is offline
If the Onan 4C is anything like Delco X66, it works great for cleaning out carbon. Look at the back and see what it is in it.
David C.
Old 11-11-2017, 10:22:17 PM
There is already Xylene in gasoline, these are products from the crackers and reformer, but they are expensive so Mogas does not have a lot of them.
100LL however is loaded with the stuff.....
I used use Xylene as a co solvent to blend with methanol and other products in my racing fuel.
The ring hydrocarbons do a very good job of devolving one thing into another thing and keep the mix together.
Old 11-12-2017, 12:16:24 PM
Gunny Gunny is offline
When I worked for Cummins/Onan, i carried a few cans of it in my service truck and used it regularly.
Good stuff and works well. BUT....... Read the directions before using it and follow them for best results.
Most of my service work was on large commercial equipment, used it there at times too, works well on diesels too that had been wet stacking and were badly coked.
Old 11-12-2017, 02:22:49 PM
len k len k is offline
For loose carbon that sounded like a piston knock, dad would warm up the engine. At idle pour 1/2 a spray paint cap of gumout? down carb, then suddenly dump rest down it. Then if engine wasn't stalled yet, quickly shut off engine. Sometime next day he'ld run the car and knock was gone. Guess the stuff softens the carbon and allows it to break up and blow out the exhaust. Sounds like it was de-carboning the cylinder also.
Don't remember well, but he may have also used marval mystry oil instead.
American Carburetor 3 chamber Mixer what it fit question Wildcat Antique Gas Engine Discussion 1 03-17-2012 02:12:03 PM
Oil in combustion chamber after rebuild? Richard Miller Small Air Cooled Gasoline Engines 9 01-05-2011 11:52:04 PM
COMBUSTION CHAMBER HEAT markleyihc Antique Engine Archives 3 09-16-2004 10:51:26 AM
Sealing cracks in combustion chamber Jim Gorter Antique Engine Archives 4 07-28-2004 08:42:05 PM
Combustion Chamber Pressure Charlie Antique Engine Archives 6 02-20-2001 11:16:34 PM
