Onan 15.0 Build Sheet off Serial #
this thread has 18 replies and has been viewed 593 times
Old 11-11-2017, 07:25:34 PM
Default Onan 15.0 Build Sheet off Serial #
I was hoping someone could post a build sheet for this 12 wire 15.0RJC. I can not find the data tag anywhere on it. Any ideas where to look for the ID tag on a RJC?? Block # 306710
$160.00 and $30.00 in gas, I can turn the flywheel. The seller said the dist. quit turning, he said the gear that drives the dist. is not turning. It's been sitting for about 6 years he said.
I couldn't pass it up, Tri-fuel carb., newer starter, demand regulator with shut off solenoid. A beautifull drive pretty much all in the mountains it was!!
Thanks!
ID:	295853   Click image for larger version
ID:	295854   Click image for larger version
ID:	295855   Click image for larger version
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
Old 11-11-2017, 07:30:38 PM
Default Re: 15.0 Built sheet off serial #
A few more pictures.
The guy also has a Kohler and an Onan 12 RS both in need of repair. The RS he said started making a knocking noise.
https://cosprings.craigslist.org/for...321873785.html
ID:	295857   Click image for larger version
ID:	295858   Click image for larger version
ID:	295859   Click image for larger version
Old 11-11-2017, 07:46:19 PM
BRae's Avatar
BRae BRae is offline
Nice score!
The Following User Says Thank You to BRae For This Post:
Old 11-12-2017, 01:08:41 AM
Default Re: Onan 15.0 Built sheet off serial #
The tag on one like that are usually on The control box.. could possibly be inside?
Good deal! Hopefully the gear drive for the distributor is not ground up..
Old 11-12-2017, 01:18:59 AM
Joe,
Have you ever seen a bad camshaft on a JC?
Is Florida agreeing with you?
Old 11-12-2017, 12:49:45 PM
Yea, "Nice Score".
I have not found a data tag "inside" the control box yet, usually they are inside door on a housed set, but outside on the rest.
I have not seen a muffler set up like that until now, interesting set up.
The Following User Says Thank You to Max Thompson For This Post:
Old 11-12-2017, 02:53:56 PM
EnginePat EnginePat is offline
Could the pin on the distributor be broken?
Really nice score!
Pat
5GO 3/RA
7.5 jb's x3
The Following User Says Thank You to EnginePat For This Post:
Old 11-12-2017, 03:11:43 PM
Originally Posted by nothingbutdarts View Post
Joe,
Nope... first time for everything tho.. I think I scraped one when I moved to..
Flordia is cool.. but alot of people have keys disease when it comes to getting stuff done.. unless you wave a 100 bill at them
Old 11-13-2017, 05:09:31 PM
OnanParts's Avatar
OnanParts OnanParts is offline
Came up with 15.0 RJC-18R/30436C shipped Oct. 1990
The Following 5 Users Say Thank You to OnanParts For This Post:
Old 11-13-2017, 05:12:49 PM
OnanParts, Thank You!
Might I be able to get a copy of the build sheet though?? I'm really trying to find of it full output in single phase.
Onan 15 JC build sheet? nothingbutdarts Onan Generators 7 06-07-2017 11:48:15 AM
Onan 12.5 Build Sheet Please J-Man Onan Generators 11 02-05-2016 10:59:40 AM
build sheet wanted MDJF 15? serial # 358695 BigBlockChev Onan Generators 1 12-18-2015 08:10:12 PM
Onan 15.0 KW Build Sheet suntreemcanic Onan Generators 4 03-14-2015 06:26:53 PM
Onan 15.0JC Build sheet JSConan Onan Generators 6 01-05-2012 07:49:52 PM
