Onan Parting Out Thread (Used Onan Parts only!)
this thread has 498 replies and has been viewed 35866 times
Old 11-01-2017, 08:59:04 AM
LRomero LRomero is offline
Default Re: Onan Parting Out Thread (Used Onan Parts only!)
Originally Posted by EICBob View Post
Needed, a YD voltage regulator board, Onan #300-1006(D)
Am on day 3 of running my JC and the repairs I made to the board originally were apparently not enough to keep the unit happy.
-Bob
Crap. I got a Sx460, flightssystems, and 2 Onans at home but i wont be back home until thursday evening.
The Following User Says Thank You to LRomero For This Post:
Old 11-01-2017, 12:46:55 PM
EICBob EICBob is offline
By the looks of things I will still be on generator power till sometime Saturday or Sunday at the earliest!
-Bob
Old 11-22-2017, 09:29:18 PM
EnginePat EnginePat is offline
Still looking for the side cover with screw that covers the carb on my jb, please
Pat
5GO 3/RA
7.5 jb's x3
Old 11-26-2017, 09:09:10 AM
mac keister mac keister is offline
6.5 NH-3CR/12014D
L753139043
Hi, I am looking for an exhaust manifold. This may have a larger outside diameter than newer models. This unit has the side draft carb. I am also looking for the exhaust port insert. Part # 154-1424 They are for exhaust heat transfer. My hunch is that one could be made out of a piece of pipe by using the other side as a template but it would be much better to get the real part.
Old 11-27-2017, 01:36:11 AM
nothingbutdarts nothingbutdarts is online now
Looking for a crank gear and an oil pump for a JC. PLEASE and Thank You.
Old 12-09-2017, 11:43:10 AM
So many people here and no one wants to sell a cover.
Pat
5GO 3/RA
7.5 jb's x3
Old 12-13-2017, 12:10:24 PM
Kidder Kidder is offline
Good Morning,
I'm looking for a good stator that fits a K450 Tag a Long.
Part number is 18503-02400.
Thought I would try my luck here before trying to rewind.
Old 12-17-2017, 12:28:10 PM
ayumifanshawn ayumifanshawn is offline
i am looking for a oil line the metal one that goes from the oil filter housing to the valve cover oil galley if any one has one pleas pm me and what you want for it thanks!
ps thats for a 7.5 jb sorry got ahead of myself.
i dont have one for sale but i do have a good one if measurements and pics would help to make one
Old 12-17-2017, 01:23:12 PM
consolenut consolenut is online now
Anyone have an exhaust manifold cover for a 6.5NH.
Onan part number 154-1888
As for the cover if someone has one they could measure and send a drawing I could probably make one.
Also looking for the oil filter adapter
Onan 122-0320
Old 12-17-2017, 03:01:30 PM
Is the exhaust cover for a "center" "down turn" exhaust exit?
ID:	298521   Click image for larger version
ID:	298522   Click image for larger version
ID:	298523   Click image for larger version
Old 12-17-2017, 05:40:30 PM
Yes center turn down exhaust
That is the cover i am looking for
Old 12-17-2017, 05:46:15 PM
It needs a little work as you can see. It's yours for the cost of shipping if you want it.
The Following 2 Users Say Thank You to nothingbutdarts For This Post:
  #493
Old 12-17-2017, 06:43:15 PM
update i made one out of a brake line thanks!
Old 12-24-2017, 04:50:23 PM
This is the cover I am looking for. Lower Left side of pic.
Pat
5GO 3/RA
7.5 jb's x3
Old 01-03-2018, 03:35:03 AM
Toesmack's Avatar
Toesmack Toesmack is offline
Images: 7
Got a nice little 6.5nh recently and with a little attention got it running and making power. Just need an electric choke control assembly. Anybody got a spare laying around? Also where do you guys go for new parts?
Old 01-04-2018, 09:38:41 PM
OnanParts is a vender here on the sight.
https://www.onanparts.com/
Old 01-04-2018, 09:56:49 PM
Toesmack I have a two 6.5NH. As a rule mine only want choked for about 2 seconds if that. Then i open the choke blade wide open. And its fine. That being said I don't use the electric choke. Only thing its used for is to hold tension on the choke blade holding it open.
Old 01-05-2018, 12:06:04 AM
Toesmack's Avatar
Images: 7
I guess I should have seen that we had a parts sponsor, but oddly enough it is the site I looked at for parts.
As to the electric choke, I find that this engine likes plenty of choke. Once I get a new oil filter and fresh oil in it, and a new oil pressure switch, I will run it long enough to dial in the carb a bit more and add some drag to the choke lever. Governor now sometimes hunts until I stabilize the linkage by hand. Holds a load pretty well though. Also it's pretty much the smoothest running 2 cylinder ever.
Old 01-14-2018, 06:53:04 PM
You might take the carb apart and clean it out. Thats usually what makes them like alot of choke.
Onan 12.0 DJC parts tim berkemeier Onan Generators 3 09-21-2011 09:11:12 PM
Onan parts Karl Onan Generators 1 04-17-2008 10:22:27 AM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Onan cck parts JDavid Onan Generators 1 03-14-2007 10:17:16 AM
Parting out engines thread Handlebar99 Antique Gas Engine Discussion 19 03-27-2006 09:44:37 PM
