Vintage Construction Equipment Graders, Shovels, Dozers & Crawlers, Pay loaders & Fork lifts
Hobart WeldMobile/Truck, 1945 with Chrysler Straight 8
this thread has 12 replies and has been viewed 774 times
Old 09-17-2019, 09:29:06 AM
mschreiber mschreiber is offline
Default Hobart WeldMobile/Truck, 1945 with Chrysler Straight 8
1 of the neatest things at the vintage construction show last weekend. They had it welding just fine. Shop built by Hobart using a Chrysler chassis/engine. .
Old 09-17-2019, 03:26:53 PM
Vanman Vanman is offline
Default Re: Hobart WeldMobile/Truck, 1945 with Chrysler Straight 8
Wow, that's really neat!
How does it drive? A clutch and trans off the back of the generator? Or a traction motor powered by the generator? Looks like it has a gear shift lever?
Old 09-17-2019, 03:31:52 PM
Neat looking machine, I bet it weighs a few tons! Doesnt look like it has much of a suspension does it. I bet it has a harsh ride!
Old 09-17-2019, 09:27:39 PM
I don't know how it works, didn't get to talk to ower very long, busy with all the stuff there.
Heres a walk around video of it.
https://www.youtube.com/watch?v=J9GktG6WB9E&t
The Following 4 Users Say Thank You to mschreiber For This Post:
Old 09-17-2019, 11:34:36 PM
ulgydog56's Avatar
now that's wild...….
The Following User Says Thank You to ulgydog56 For This Post:
Old 09-18-2019, 01:16:28 AM
Nice video! Looks like it's got a clutch pedal and a gear shift lever. If it's got some nice low gears, it ought to be able to really pull, what with all that weight on the drive wheels!
Old 09-28-2019, 01:46:09 AM
Duey C Duey C is offline
Very, very cool! My son and I have welded with a model A Ford powered welder on a 2 wheel trailer.
Worked good! Smoooooooth. Like the straight eight.
Like the Schramm air compressor tractors but way different.
Old 09-28-2019, 10:23:31 AM
Sonny Reese Sonny Reese is offline
Now THAT is one neat welder!! ---I had a Hobart 200 amp welder that looked exactly like that one!--Best welder out there!
Old 09-29-2019, 02:06:57 PM
OTTO-Sawyer's Avatar
Photo Re: Hobart WeldMobile/Truck, 1945 with Chrysler Straight 8
I have that same welder, Minus the Super Cool Hot-Rod Truck which I'd be cruising around in on a regular basis if I had it.
Mine had been powered by a Buick Straight-8 but was changed over to a freshly rebuilt Wisconsin V4 shortly before I bought it at Auction.
Whoever rebuilt the engine set the valve guides too tight and 3 of them seized up after about 10 minutes of run time so I didn't get a whole lot of practice with the welder and have yet to get around to redoing the valves.
One Cool Feature on the welder is that the center Control Unit Pops Out and can have an extension cord plugged in-between it and the welder for Remote Amperage Control, so, say if you were welding on the second floor or roof of a building with the welder down on the ground, you could adjust as needed without having to climb down or holler at someone else to change the settings.
Name:	HOBART Welder.jpg
Old 10-11-2019, 12:41:14 PM
luke000 luke000 is offline
Hello everyone, I am the owner of the Hobart Weldmobile. It is a 1945 (I think) and has a Chrysler 324 straight 8 and a Plymouth transmission (only one speed forward and reverse) The rest was all factory made by Hobart. They made a 200, 300, and 400 amp model. This is the 400 amp model, able to make 525 amps at full power.
The welder generator is directly coupled to the bell housing of the motor, and the transmission mounts to the back of the welder. The rear end seems to be a cut down chrysler axle and mated to planetary hubs for ground clearence. No suspension other than the tires.
I had been looking to get my hand on one for a few years and never saw a single one for sale, of any size, until this one popped up on eBay last year in Oklahoma. Ended up winning the auction and had it shipped back to Michigan. When it arrived it was seized in gear, but within a few hours we had it driving around, we were unable to get it welding before the snow hit. The front axle had been replaced at some point with something much too wide and a very strange bolt pattern. The 16.5 inch tires were beyond use so we flame cut some bald trailer tires just to get it rolling. This year we decided to take it down to the HCEA show having done no work on it. She fired right up and drove onto the trailer. While at the show, I worked on the generator and found a few stuck brushes and after I got them cleaned up, she welds great! We even used the welder to jump start a D6 dozer!
I plan to put on a proper front axle, new tires all around, and figure out how the governor linkage is supposed to hook up, seems I am missing some pieces that need to be made.
If anyone has any kind of information on these machines, please get ahold of me, Id love to hear/see whatever you have!
The Following 11 Users Say Thank You to luke000 For This Post:
Old 10-11-2019, 03:03:10 PM
Thumbs up Re: Hobart WeldMobile/Truck, 1945 with Chrysler Straight 8
Welcome Aboard The Stak Luke.
That Thing is Beyond Kool !
Of course now that you're on here, we're gonna need More Pictures and maybe a Video of it.
Old 10-12-2019, 06:54:37 AM
Peter Holmander Peter Holmander is offline
Really neat machine. Thanks for sharing !!!
Old 10-12-2019, 09:23:02 AM
Heins Heins is offline
I would like to see how the drive line drops down behind the welder to the rear end.
Chrysler Spitfire Straight Eight Marshall Henderson Multi-Cylinder Stationary Gasoline Engines and Power Units 11 03-31-2015 10:13:21 AM
Hobart 17-G-2045 1945 almrens Military MEP and Aircraft Gen-Sets 20 11-20-2013 06:25:33 PM
1940 Chrysler straight 8 Donnie Hargreaves Antique Autos and Trucks 2 03-05-2012 02:57:05 PM
Chrysler straight 8 whats it worth tad862 Multi-Cylinder Stationary Gasoline Engines and Power Units 5 01-27-2012 01:14:23 PM
Lifting eye-rod for hobart w/ 6 cyl. chrysler RobLCook Welding Shop 2 04-05-2008 01:28:24 PM
