Monitor ( Auto Config.)
this thread has 3 replies and has been viewed 1796 times
Old 11-14-2016, 08:46:22 AM
Owen Bosma's Avatar
Owen Bosma Owen Bosma is offline
Angry Monitor ( Auto Config.)
I have a flashing "Auto Config. Please wait" banner flashing at me on the monitor. It had been doing this for a while off and on, but now it won't go away.
It seems that the set up buttons and the off on switch have been disabled. The monitor is a Acer do I have to trow it out, or is there a cure.
.......... Owen
http://home.cogeco.ca/~obosma
James Bosma You Tube
Old 11-17-2016, 09:01:27 PM
Lead Head
Default Re: Monitor ( Auto Config.)
The buttons might be broken, or one of them is stuck in the "pressed" position. If I had to guess, it might be the button labeled Config, Menu, or Auto Config.
Old 11-17-2016, 10:21:17 PM
Look for a connector leading to button board and try just unplugging it... assuming power button is not on same strip.
Doc
Old 11-19-2016, 09:07:13 AM
Owen Bosma's Avatar
Thanks for the help .............. some of the buttons where stuck including the off and on switch witch had not worked for some time.
I laid the monitor on its back and gave the buttons a good soaking of contact cleaner from the outside, and worked the buttons and left it for a few ours.
All the buttons are free now, and the problem is gone!!
.......... Owen
The Following User Says Thank You to Owen Bosma For This Post:
VG4D Firing order and cylinder config. dbarn6 Wisconsin Engines 10 09-03-2013 08:01:09 PM
IHC LB mag auto advance rockisland3h Magnetos, Ignition Coils and Spark Plugs 7 06-25-2010 08:38:25 PM
auto ads Al Wait Hit & Miss Gas Engine Discussion 3 04-19-2007 11:55:15 AM
Auto-Sparker Matt J Antique Engine Archives 0 10-07-2001 02:05:16 PM
