Wanted Info on Ruston Hornsby Engines
this thread has 3 replies and has been viewed 3175 times
Old 08-25-2012, 05:41:43 PM
J.R.Smith J.R.Smith is offline
Question Wanted Info on Ruston Hornsby Engines
Hello All! Wanted Info on 2 diffrent Ruston Hornsby Engines. Owner, Operator Manuel. Starting instructions. Year built? You name it, I need it. #1, Mark CR, No. 216075. #2, Size 1Z, Class HR, No. 435061. Thanks for ANY and ALL Help!
J.R.Smith, Tatum,Texas I don't know if they will run this far South! Look Listen and Live! Alway Expect a TRAIN!
Old 08-25-2012, 10:46:20 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Default Re: Wanted Info on Ruston Hornsby Engines
JR are these the engines you need info on?
ID:	143342   Click image for larger version
ID:	143343   Click image for larger version
ID:	143344   Click image for larger version
The Following 2 Users Say Thank You to Dwayne Fuller For This Post:
Old 08-26-2012, 01:55:34 PM
Along with the usual Brit sources, you might try tomm.com.au, an Australian site, as they seem to've had a good number imported there. Good luck.
The Following User Says Thank You to Bud Tierney For This Post:
Old 08-27-2012, 01:52:02 PM
ListerDiesel's Avatar
435061 is mid 1960's, probably 1964. Our 1ZHR is 435070:
That was sold 31st January 1965, so probably a 1964 build engine, possibly they built a batch of them.
The Corn Elevator engine is probably back in the 1940's or so.
Email Ray Hooley, his contact details are on this website:
http://www.oldengine.org/members/ruston
Peter
The Following User Says Thank You to ListerDiesel For This Post:
Ruston Hornsby CR diesel info Tom Weatherford Antique Gas Engine Discussion 0 03-10-2012 07:35:47 PM
Ruston Hornsby mill engine info needed mechman Vintage Diesel and Oil Engines 3 01-12-2012 11:17:40 PM
Ruston Hornsby Diesel info wanted Scott Hosack Vintage Diesel and Oil Engines 4 02-01-2009 01:57:11 PM
Ruston Hornsby ID info needed. Inter Bloke Vintage Diesel and Oil Engines 13 03-10-2008 08:01:25 AM
Ruston Hornsby info wanted, please. DirtbikePilot Antique Gas Engine Discussion 2 10-01-2007 03:23:44 AM
