IHC vs McCormick Deering M Engines
this thread has 13 replies and has been viewed 2606 times
Old 03-09-2013, 09:58:23 PM
jboyer1028 jboyer1028 is offline
Default IHC vs McCormick Deering M Engines
What is the difference between the McCormick Deering and IHC M engines?
Jeff
Old 03-09-2013, 10:31:41 PM
ravensrayne ravensrayne is offline
Default Re: IHC vs McCormick Deering M Engines
As far as I have ever been able to tell, just the name plate...
The Following User Says Thank You to ravensrayne For This Post:
Old 03-10-2013, 08:43:23 AM
WildIrishman52's Avatar
WildIrishman52 WildIrishman52 is offline
Images: 1
I have always understood the the MD engines were primarily spark plug (although, I have heard that they could have been special ordered with an ignitor). The IHC engines were ignitor fired. Joe
The Following 3 Users Say Thank You to WildIrishman52 For This Post:
Old 03-10-2013, 01:51:59 PM
oldironlindy oldironlindy is offline
I could be wrong but I always thought that the ones that were badged ihc were sold into industrial aplications and the mccormick badged ones were sold into farm applications. Kinda like they did with farmall and international tractors.
The Following 2 Users Say Thank You to oldironlindy For This Post:
Old 03-10-2013, 02:51:33 PM
bigGURN's Avatar
bigGURN bigGURN is offline
Images: 1
Mine has a McCormick badge on one side of the hopper and an international on the other... its igniter fired.
The Following User Says Thank You to bigGURN For This Post:
Old 03-10-2013, 05:13:06 PM
Found an interesting 1982 article in Gas Engine Magazine on the web.
International engines were manufactured in the 'Milwaukee Works' at Milwaukee, Wisconsin and the McCormick Deering 'M' engines in the 'Deering Works' at Chicago, Illinois.
Read more: http://gasengine.farmcollector.com/G...#ixzz2NAp1YdDO
The Following User Says Thank You to jboyer1028 For This Post:
Old 03-10-2013, 05:28:39 PM
bigGURN's Avatar
Images: 1
That would make sense...
Old 03-10-2013, 07:56:49 PM
flatbeltuzr flatbeltuzr is offline
I was under the impression that it had something to do with a law suit, agreement with the US government. Best I can tell the badge change started sometime in 1919. I have crankcased tagged International 1918 and 1919 11/2 hp m and I have a 3hp hopper tagged International 1919. All my 1920+ 11/2 & 3hp M are McCormick tagged. The same holds true for the 6hp and 10hp the early ones were tagged Int. I also thought production switched from the "tractor works" to the "deering works" in 1922 based on production records from the IHC archive.
The Following User Says Thank You to flatbeltuzr For This Post:
Old 03-10-2013, 08:24:57 PM
ScooterBob ScooterBob is offline
We have an International small hopper tag on an overstrike ignitor 1-1/2 hp, SN A51958, dates to 1920.
The Following User Says Thank You to ScooterBob For This Post:
Old 03-10-2013, 08:38:27 PM
51958, earlier than mine.
Old 03-10-2013, 09:31:05 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
According to Cyrus McCormick in his book, "Century of the Reaper", the McCormick-Deering line came into being in 1923. (Page 187-188)
It started as the result of a 1918 consent decree with federal courts because the International Harvester Company had been selling different lines in each town through two dealers which made the public think they were competing when they were not. For instance Mogul and Titan tractors.
The Following 2 Users Say Thank You to John Hamilton For This Post:
Old 03-10-2013, 10:23:48 PM
Jim Walker Jim Walker is offline
jboyer1028,
Thanks for the very informative article. Can you supply the link that covers the next issue covering the 3-6 and 10hp engine history.
Thank you, Jim
Old 03-11-2013, 01:08:46 PM
Originally Posted by Jim Walker View Post
jboyer1028,
Thank you, Jim
http://gasengine.farmcollector.com/G...mber-1982.aspx
Old 03-11-2013, 02:30:00 PM
IHC - McD also made a major change in early to mid 1919. They went from brass tag on the hump on the block to the familiar aluminum tags on the hoppers. At the same time, they went from the early single bearing understrike igniter (hard to find), to the later double bearing overstrike type. This change also meant major changes to the igniter trip assembly and operation as well as the fuel pump, a big deal back then.
I have an early 1919 3 HP IHC M, that was used in a tannery in Newark NJ (100th engine of that type) made that year. In 1920, the company ordered a second 3 HP (1920), and when it arrived, they saw that the ignition set up was different (both engines are igniter fired). The tannery wanted to retro-fit the 1920 with the 1919 ignition set up, but was told by IHC that the cost would nearly be as much as a new engine, as the 1919 parts had been discontinued. Parts needed would have been: igniter, trip finger and mount, pishrod, cam and camshaft, fuel pump and activating lever, and miscelenous hard ware, plus labor to install all of the above.
McCormick Deering 6 help Dcarpent Antique Gas Engine Discussion 4 01-18-2012 10:10:40 PM
Two McCormick-Deering engines and the WHAT is it? Denis Rouleau Antique Gas Engine Discussion 6 10-18-2011 11:11:36 PM
McCormick Deering M 3 HP MDIHC Antique Gas Engine Discussion 1 09-13-2009 11:26:55 PM
McCormick-Deering Jerry B Antique Engine Photos 1 06-19-2009 08:04:27 AM
McCormick Deering Engines John Taylor in Tennessee Antique Engine Archives 0 07-01-2002 04:57:32 PM
