Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
Small Four Cylinder Flathead Identity Sought
this thread has 38 replies and has been viewed 8296 times
Old 01-09-2014, 08:34:58 AM
Peter Short Peter Short is offline
Default Small Four Cylinder Flathead Identity Sought
I have a small flathead four cylinder engine – maker unknown. However there are some unusual features on the little engine, perhaps kind reader you will recognise and identify the maker.
- To give an idea of the engines size - the flywheel measures approximately 300mm, say 12" diameter. The cylinder head is 410mm long (16"), spark plug centres 95mm (3 3/4') so bore somewhat less than this.
-Barrel crankcase i.e. crankshaft can only be fitted from the end.
-There is no sump, just a sheetmetal cover plate. What looks like a separate cast iron tank for oil (below magneto).
-Finned exhaust manifold is part of the block.
-Removable head.
-Carb is Mayer Carburettor Co. Buffalo, New York.
-Magneto: Severn HT4, USA.
-Engine mounts? Not a lot....there are the two square-head screws on the rear face of the block at mid-level and the snout of the timing cover has a machined outside diameter.
-Cone clutch.
-No starter motor.
-Priming cups fitted on side of cylinder head.
- Spark plugs (KLG A30) are 7/8" - 18 TPI.
-Threads and hex sizes are probably American rather than British (not 100% sure yet).
-Spigot on head looks suitable for short arm-mounted cooling fan, driven from magneto drive extension.
Thanks for any help!
ID:	184365   Click image for larger version
ID:	184366   Click image for larger version
ID:	184367   Click image for larger version
Old 01-09-2014, 08:59:17 AM
Default Re: Small Four Cylinder Flathead Identity Sought
More photos of the little engine:
ID:	184369   Click image for larger version
ID:	184370   Click image for larger version
ID:	184371   Click image for larger version
The Following User Says Thank You to Peter Short For This Post:
Old 01-09-2014, 09:15:53 AM
More photos, hope these help someone to recognise this old timer.
ID:	184373   Click image for larger version
ID:	184374   Click image for larger version
ID:	184375   Click image for larger version
Old 01-09-2014, 09:22:42 AM
I asked the same questions and posted the same photos about one year ago on the TOMM forum - no one recognised it....so I thought I would try the Smokstakers
http://forums.tomm.com.au/index.php/topic,2842.0.html
Old 01-09-2014, 12:06:38 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Peter, Interesting old engine. You may get more response if you post this in the antique truck section on smokstak.
Old 01-09-2014, 03:15:25 PM
That's the third finned-exhaust inline that's been on here...the first, in one piece, some time back and perhaps in AU (it had a portion of the fins ground off to make room for what was guesstimated to be a distributor replacement)...the second one, disassembled, very recently...I don't believe either got a definite ID, but I haven't tried to bring them up...
Old 01-10-2014, 01:27:02 AM
dkamp dkamp is offline
eMail NOT Working
I have no clue... but it's definitely COOL!
The 'character' suggests that it's older than say... 1928... and although it doesn't have any obvious 'features' that make it so, it kinda looks 'marine'.
I dunno if Caille ever made a four like this, but the crankshaft removal cover setup just kinda looks Caille'y...
Old 01-10-2014, 08:39:52 AM
Richard H. Gambrell Richard H. Gambrell is offline
Many, many years ago, I looked at a Studebaker engine and that kind of reminds me of that one. It has been 45 years ago, so I can't say for sure.
Richard
Old 01-12-2014, 07:17:24 AM
Thanks everyone for your replies so far. I haven't looked yet for the other similar engines posted here (thanks Bud), will do so.
Richard,
this engine is pretty small - e.g. cylinder head is only 16" long - a bit small for Studebaker?
Old 01-20-2014, 01:32:41 AM
coyote62ny coyote62ny is offline
this could be an old inboard marine engine.
Old 01-25-2014, 08:17:47 PM
nblack nblack is offline
Agree with the consensus. Definitely looks marine. Dry sump, maybe had the external water pump driven by the accessory drive in front of the LT magneto? Interestingly, the intake manifold is cast into the block. Another thing I noticed is that the plugs are two piece, which puts it in the range of years as a Model T, (I think). The sprocket has me baffled, though, unless it was part of a double chain coupling. Which seems kinda out of the rest of the engines supposed time period. What are your plans with it? Is it even still loose?
Old 01-26-2014, 08:16:41 AM
Would a marine engine have a cone clutch?
There doesn't seem to be any corrosion in the water pipes (e.g.salt water cooling).
Old 01-26-2014, 12:29:30 PM
JerryLee JerryLee is offline
I am thinking very early aircraft engine. (Dry sump, chain drive)
Old 01-26-2014, 06:05:49 PM
gootsch gootsch is offline
It is interesting that there are no obvious motor mounts.
Old 09-21-2014, 10:26:26 PM
SteamfanMN SteamfanMN is offline
Did you ever find out what this was? Very neat engine!! I wouldn't mind finding something unique as this. Could you possibly look up engines that used that carb? Or search by something unique to this engine? Like that cone clutch or dry sump.
Old 09-22-2014, 12:00:35 AM
While highly unlikely I would like to suggest maybe some sort of rail speeder engine? I don't know why it would be dry sump though if it is otherwise I'd say marine application of some sorts.
Old 09-22-2014, 07:40:38 AM
Hi Steamfan,
I haven't found out any more on this engine, I was hoping someone would recognise it, but not so far...
I have tried searching on the Mayer carb and the Severn mag, but haven't found any list of users so far.
I didn't find anything much about the magneto.
The carb search turns up more info, e.g. an advert from 1913 and one or two for sale.
Also a website which features carbs for the Ford Model T - seems like there were a lot of carburettor manufacturers out there! The Mayer carb for the Model T is arranged differently, but looks to use the same basic design.
Quote: This is a Mayer. They are an interesting carb. This one is restored and running and for sale. It is one of the self regulating type, it has five little brass balls that raise off their seats to regulate the air flow and mixture. Very well built, higher quality than many of the carbs are.
http://www.strombergof.com/Other_Carburetors.php
Old 09-22-2014, 10:42:16 PM
Hey Peter I did some more searching and found a marine engine with a couple similarities. That chain sprocket was perhaps for starting it seems since there is no starter or crank start from the front.
http://www.oldmarineengine.com/discu.../3433/7689.jpg
Perhaps someone will know now. Still a long ways to go but I think marine is the right track.
The Following User Says Thank You to SteamfanMN For This Post:
Old 09-23-2014, 01:54:57 AM
Do put this on oldmarineengine..Richard Durgee there is a mine of old marine engine info; if it's US marine, he'll probably know it---I believe he posts here, but may not've seen this...
If the marine end doesn't pan out, you might do a little research on CycleCar engines...the 1913 carb ad puts it in the right time period for them, and some quite small 4cyl's were developed for those builders that wanted something smoother than the usual MC engines...
The Following User Says Thank You to Bud Tierney For This Post:
Old 07-27-2018, 08:21:59 PM
Craig Gillingham Craig Gillingham is offline
It appears to be out of a Dayton cyclecar. I'm guessing it's only about 2' long overall, still, it must have a bit of weight to it if it's all cast iron.
The photo came from here:
https://www.ebay.com.au/itm/1914-Day...YAAOSwkEtbWNoj
The Following 2 Users Say Thank You to Craig Gillingham For This Post:
Le Roi 2 cylinder flathead info sought OSEnginelover Antique Gas Engine Discussion 22 12-01-2014 12:21:55 AM
Small Four Cylinder Flathead Identity Sought Peter Short Multi-Cylinder Stationary Engines and Power Units 1 01-09-2014 08:49:14 AM
Wheelbarrow cart identity sought..... Andrew Walker Antique Gas Engine Discussion 1 07-03-2011 04:15:38 PM
DelcoLight Generator Identity and Info Sought Dave Carter Generators & Electric Motors General Discussion 9 07-22-2006 11:20:16 PM
Compressor Identity Sought Dusty Antique Engine Archives 2 10-24-2002 08:57:58 AM
