Smokstak Down Under
What Parts Do You Need?
this thread has 195 replies and has been viewed 25400 times
Old 07-29-2016, 07:16:59 AM
steeleye steeleye is offline
Default Re: What parts do you need?
Gday all. I'm searching for the Chimney Cover or crown piece of DELCO 750 32vdc plant. It goes over the top covering the overhead valves and stuff. https://www.youtube.com/watch?v=vD6g...&feature=share
Old 08-20-2016, 10:59:44 PM
Lester Bowman Lester Bowman is online now
I need several really old "Acorn" style oilers...they look like an Urn with a fancy finial top. 1/8" NPT or smaller. Anything?
Old 08-21-2016, 06:26:46 AM
Robbo Robbo is offline
Hi all, I am in need of a fuel pump for a Four horse power horizontal Famous.
Also need the hand priming mechanism. Am willing to work with a rough casting.
Robbo
Old 08-21-2016, 07:30:00 AM
Nathan Woodruff Nathan Woodruff is offline
Hi Robbo, There has been a lot of 4hp Famous parts on ebay. It might be worth a look.
Regards, Nathan
Old 08-24-2016, 05:41:31 AM
vs ss vs ss is offline
HI,just thought I would let everyone know that I got my carby and a spare Maggie for my Wisconsin from the user here called famous fitter. A top bloke and great to deal with,thanks again justin.
Regards mike.
The Following User Says Thank You to vs ss For This Post:
  #86
Old 08-27-2016, 04:58:09 PM
Ron L Smith Ron L Smith is offline
Looking for parts for a 2hp type a United engine, goose neck style igniter trip arm and inlet and exhaust valves
Ron
Old 08-27-2016, 05:02:26 PM
Scotty 2 Scotty 2 is offline
Regards mike.
Ain't that the truth.
The Following User Says Thank You to Scotty 2 For This Post:
  #88
Old 09-04-2016, 01:51:10 AM
Pascal22 Pascal22 is offline
Hi to all,
I'm pascal and I'd like to run an early Lister J
As it lacks many parts on her, I'm looking for
Connecting rod J18 with bearings and bolts
Valve cover inlet j72
Valve cover exhaust j73
Pm me please
Thanks in advance
Pascal
Old 09-04-2016, 06:22:08 AM
Trevor A Cole Trevor A Cole is offline
Default Tangye flywheels
I need two Tangye flywheels 44 or 45 inch diameter please. Also early fuel tank 3 hole mount. Anything considered.
Thank You
The Trev
Old 09-04-2016, 09:40:20 AM
Adam Jones Adam Jones is offline
Hi guys I'm currently restoring a 1927 Briggs and Stratton FH and I'm missing the small right angle bracket that screws to the side of the crankcase and you attach the governor Spring to it. See photo I've copied off the Internet of what it looks like.
Thanks Adam
Old 09-10-2016, 02:14:18 AM
mightgo mightgo is online now
Hi All. Looking for in.ex.manifold for 5 hp.SR Lister.Thanks.
Hi all,looking for in.ex.manifold for 5 hp Lister SR1.Thanks.
Brian.
Old 09-10-2016, 04:49:49 PM
MaxLeggett MaxLeggett is offline
Default Capel LBV 5hp
Commenced fixing up Capel engine. Need carby inlet pipe work and associated bits, (only have carby) water jacket head, exhaust pipe work and muffler, fuel tank, crank handle. Probably more as I get going / learn more.
Max
Old 11-02-2016, 05:32:06 AM
OzEngines's Avatar
OzEngines OzEngines is offline
R&V Ignitor to suit a 1903 vertical R&V engine, this is the horizontally mounted ignitor.
Old 11-02-2016, 05:49:52 AM
Michaely Michaely is offline
American style largish transporter to suit a 8hp Waterloo Boy. Can swap an English style to suit 4hp blackstone, Hornsby etc.
Mike
Old 11-07-2016, 05:19:23 AM
Jack5131 Jack5131 is offline
Ronaldson tippett type N 3hp water hopper
Old 11-07-2016, 05:43:33 AM
rodneyt rodneyt is offline
what type - fabricated steel, or cast iron?
with or without cap?
ps i now only have a rusty hulk, but it has a good pair of flywheels.
it was the spare parts engine for others.
i got it off a guy who put the piston into a Howard DH22 to replace one that got rusted.
Old 11-07-2016, 06:31:18 AM
Cast iron would be preferred, but anything would do at the moment
Old 11-07-2016, 10:12:26 PM
klanger57 klanger57 is offline
Looking for a good cylinder for single cylinder Stuart Turner P5 marine engine.
Kev
Old 11-08-2016, 12:04:11 AM
waynocp waynocp is offline
hi all i am still in need of a flywheel like hornsby,national etc around 52 inches diameter,if you know someone or have seen something out and about please send me a message ,cheers wayne
Old 01-17-2017, 03:53:00 PM
Emu3hp Emu3hp is offline
Buzacott 4hp horizontal parts available
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Antique Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Antique Gas Engine Discussion 8 03-16-2013 11:52:47 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
