Smokstak Down Under
What Parts Do You Need?
this thread has 195 replies and has been viewed 25403 times
Old 12-04-2017, 05:15:09 AM
Craig Gillingham Craig Gillingham is offline
Default Re: What parts do you need?
I'm after working on a project where I need the old-style BA nuts and bolts. Does anyone have a selection of those from the sizes 2BA to about 6BA?
Old 12-24-2017, 06:56:42 AM
sundial sundial is offline
Hi All,
I'm looking for a sketch (dimensioned) of a Sundial 2hp muffler. My engine doesn't even have the rusty remains so I have nothing to rebuild from.
Old 12-24-2017, 07:15:03 AM
Scotty 2 Scotty 2 is offline
Hello Mr sundial
I'm pretty sure Don Reid sells those mufflers. It might save making one.
Vintage engine spares. Haven't got the number at hand
Cheers Scott
Old 12-24-2017, 06:37:48 PM
Mick's Avatar
Mick Mick is offline
Images: 21
I have an original 2 hp sundial muffler here if ya interested
Old 12-29-2017, 06:09:04 AM
Oil Power Oil Power is offline
Hi Craig Gillingham
I think you will be able to get the BA screws you require from Model Engineering Supplies of Tullamarine Vic. http://www.mesupplies.com.au
Hugh
The Following User Says Thank You to Oil Power For This Post:
  #146
Old 12-29-2017, 04:59:14 PM
Hugh, thank you. I didn't know that shop existed.
The Following User Says Thank You to Craig Gillingham For This Post:
  #147
Old 01-04-2018, 09:46:06 PM
Hi Mick
Thanks for the reply Would much appreciate that ..
new to this board so how do I contact you
Rgeds Tony K
Old 01-05-2018, 02:20:43 AM
DScott DScott is offline
hi tony
click on micks name.
there will be a drop down box, you can send an email or private message,
to check to see if you have a private message look at top right of screen.
cheers des
Old 01-05-2018, 09:29:03 AM
rodmart2008 rodmart2008 is offline
Hi Group
after a couple of b sundial parts a intake valve and fuel pick up line the part that goes into the tank thanks Rod
Old 01-08-2018, 04:14:23 PM
Greg M Greg M is offline
I need an ignition backing plate for a Villiers MK 12 single cylinder, air cooled, four stroke, gas engine.
Thanks,
Old 01-08-2018, 04:33:02 PM
Thanks,
Hello Greg
It's good to see someone bringing one of these back to life. Generally speaking, they're thrown away over here. Not sort after at all.
That should be an easy one. There is a nice chap on ebay here in Australia with a lot of Villiers stuff. I'd be surprised if he hasn't got anything.
Good little engines the Mk 12.
Is it the Australian built version?
Here is a link to the gasket set he has for the Mk 12. You should be able to contact him through it.
If he hasn't got one, I would have one at home you could have.
https://www.ebay.com.au/itm/villiers...IAAOSwFMdaUVzL
Cheers Scott
The Following User Says Thank You to Scotty 2 For This Post:
  #152
Old 01-08-2018, 10:18:01 PM
Thank Scott! I'll try contacting that fellow when I get home in a couple of days and can have a close look at the one I have in case there are differences between the Australian version and mine which I assume to be British as it's on a mk 2 Monrotiller. Seems at some point the tiller was run into something unforgiving and the cooling tin pushed the ignition backing plate towards the cylinder bending and cracking it. Otherwise I believe I have all the bits to make it right and would like to see it earning its keep in the wife's plot this spring.
Cheers, Greg
The Following User Says Thank You to Greg M For This Post:
  #153
Old 01-08-2018, 10:41:22 PM
Hello Greg
The plates should be the same.
Let us know how you get on as those plates are common over here.
Cheers Scott
  #154
Old 01-12-2018, 07:42:20 AM
Adam Jones Adam Jones is offline
Hi guys itís a long shot but looking for a gearbox and drive shaft for a Ferrier 120 outboard Motor.
Thanks Adam
Old 01-12-2018, 04:41:38 PM
Emu3hp Emu3hp is offline
Have you tried Sally Lunn on facebook. He collects outboards hes on vintage mowers buy swap sell group
Old 01-12-2018, 07:03:29 PM
IHC150 IHC150 is offline
Hi all, has anyone got a big end bearing for a Ronaldson Tippett CK 2 cylinder (25 - 27HP) that you would be willing to sell? Hoping to get one from a wrecked machine - just needs to have sound backing metal as I'll re-whitemetal and get bored to the correct size. In the CK catalogue the part number is CK92. Cheers Lawrie
Old 01-14-2018, 07:49:17 AM
Hi Matt I have but doesn’t have any Ferrier parts unfortunately
Old 01-18-2018, 06:07:17 AM
hi
looking for a fairbanks morse z 1 1/2hp govenor/ maggy bracket,
after the main bracket [we have the cam gear and all tthe other parts].
please let me know what you have.
cheers des
Old 02-04-2018, 01:39:49 AM
cobbadog cobbadog is offline
Hi guys,
I'm looking for a muffler to suit "RAY" our 8hp CD Lister diesel. I think these were a cast iron muffler and has about a 3" inlet
Old 02-04-2018, 05:25:56 AM
crashley crashley is offline
I am looking for a crby or at least the fuel bowl off a crossley ph1065
engine
ashley
crashley@wideband.net.au
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Antique Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Antique Gas Engine Discussion 8 03-16-2013 11:52:47 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
