Smokstak Down Under
Farm Pumper
this thread has 10 replies and has been viewed 1342 times
Old 02-08-2018, 05:50:38 AM
Adrian Holland Adrian Holland is offline
Default Farm Pumper
Good day , just a quick question, has anyone used glass marbles instead of brass ball , as Iím finding it hard to obtain the brass ones , thanks
Old 02-08-2018, 06:02:43 AM
Famous Fitter Famous Fitter is offline
Default Re: Farm pumper
Hi Adrian
What about hard rubber balls ? Glass would work but not forgiving ?
Search in the USA for the brass balls - you might get lucky
Cheers Justin
Old 02-08-2018, 07:00:52 AM
Nathan Woodruff Nathan Woodruff is offline
Hi Adrian,
Stainless might be an option. I have used it on a smaller scale. I find it works well with brass seats. Use on as a sacrificial ball and give it a tap into the seat to set the seat so the new stainless balls should seat nice. Good luck with trying out the glass ones.
Regards, Nathan
Old 02-11-2018, 05:00:26 PM
Darryl Darryl is offline
Default Re: Farm Pumper
Look for a brass monkey ( sorry ! )
The Following 2 Users Say Thank You to Darryl For This Post:
Old 02-11-2018, 05:12:25 PM
Jake Jacobs Jake Jacobs is online now
brass monkey
Every sailing ship had to have cannon for protection. Cannon of the times required round iron cannonballs. The master wanted to store the cannonballs such that they could be of instant use when needed, yet not roll around the gun deck. The solution was to stack them up in a square-based pyramid next to the cannon. The top level of the stack had one ball, the next level down had four, the next had nine, the next had sixteen, and so on. Four levels would provide a stack of 30 cannonballs. The only real problem was how to keep the bottom level from sliding out from under the weight of the higher levels. To do this, they devised a small brass plate ("brass monkey") with one rounded indentation for each cannonball in the bottom layer. Brass was used because the cannonballs wouldn't rust to the "brass monkey", but would rust to an iron one.
When temperature falls, brass contracts in size faster than iron. As it got cold on the gun decks, the indentations in the brass monkey would get smaller than the iron cannonballs they were holding. If the temperature got cold enough, the bottom layer would pop out of the indentations spilling the entire pyramid over the deck. Thus it was, quite literally, cold enough to freeze the balls off a brass monkey.
The Following 3 Users Say Thank You to Jake Jacobs For This Post:
Old 02-11-2018, 08:15:30 PM
radiodoc radiodoc is offline
You would be surprised at the number of persons upon hearing that expression think it is something dirty...
Old 02-11-2018, 08:41:53 PM
Eric Schulz's Avatar
Eric Schulz Eric Schulz is offline
That old brass monkey story would be pure fiction. Probably some people think it is true!
Eric
The Following User Says Thank You to Eric Schulz For This Post:
Old 02-11-2018, 09:03:30 PM
Scotty 2 Scotty 2 is offline
Eric
Hello Eric.
Which old brass monkey story? The cannon balls or monkey balls?
Anyways, I've used stainless balls in pumps, and for the amount of time they're used for a lot of us (ie a few hours a year), the stainless ones cause no significant wear but, as Justin says, long term use would flog the brass out. I did flog some hard plastic balls out of the cats toy once. I got into trouble over that one, but they worked well.
Never thought of using marbles. Why not?
How would making Teflon or nylon or similar inserts for the valve seats work so the brass valves aren't flogged out with stainless balls?
Cheers Scott
Old 02-12-2018, 02:29:25 AM
Try this mob.
Pinterest
Old 02-12-2018, 12:55:34 PM
Glass may be too light to seat when needed. Also, the constant pounding of the glass against the seat may end up fracturing the glass into fragments. As others noted - hard rubber might be a better solution, or check out other vendors like McMaster Carr for your needs. for the short term use, a stainless steel ball should work fine. It probably would weigh the nearly the same as the brass one it replaces, so pounding should not really be an issue
Old 02-18-2018, 03:27:06 AM
Had a great Display today and the pumper went really great
The Following 2 Users Say Thank You to Adrian Holland For This Post:
Farm Pumper Phil Dowe Smokstak Down Under 60 12-07-2016 06:58:19 AM
Farm pumper Darryl Smokstak Down Under 5 04-02-2015 12:58:12 AM
Buzacott Farm Pumper gozoish951 Antique Gas Engine Discussion 1 12-31-2013 06:41:25 PM
Centenary of the Farm Pumper Patrick M Livingstone Antique Gas Engine Discussion 0 01-11-2009 03:53:18 AM
F&J Farm Pumper Patrick M Livingstone Antique Engine Archives 0 07-12-2002 10:19:08 PM
