Cleaning Oily Wood?
this thread has 9 replies and has been viewed 2297 times
Old 09-12-2010, 09:09:15 PM
Dave Frost Dave Frost is offline
Default Cleaning Oily Wood?
Have a 23 FM 1 1/2HP that I'm getting around to putting back together. Has a two handle skid that may or not be original. I plan on running this old throttler in work clothes so I'm not looking for a perfect skid, but would rather clean the caked on oil off and not destroy the skid. Is there anything that I can spray on and hose off without fear of damage? I was thinking Simple Green, deck cleaner or a car wash but thought I'd ask the experts out there for the correct way to tackle this. Thanks in advance, Dave
Old 09-12-2010, 09:47:11 PM
Farmer John Farmer John is offline
Default Re: Cleaning Oily Wood?
i would think deck cleaner would bleach it some. maybe some oven or engine cleaner from a auto parts store.. be sure to try a small spot first what ever you do ,maybe underneath to see the results before doing very much...good luck ..john
Old 09-12-2010, 11:03:00 PM
Sam Hamilton's Avatar
Sam Hamilton Sam Hamilton is offline
I think that I would try spraying it down with kerosene first. Any strong solvent or anything water based is likely to damage some of the finish. Kerosene is an excellent cleaner and doesn't leave any residue. If it soaks into the wood, it will all evaporate within a few days.
Old 09-12-2010, 11:08:22 PM
Len Spoelman Len Spoelman is offline
Steam Cleaner should cut the oil. Be careful to check if it is painted and whether the steam is lifting the paint. Maybe try to finish it with linseed oil?
Old 09-13-2010, 12:03:22 AM
Axtion Jim S Axtion Jim S is offline
I just use a the solvent in my parts cleaning washer, its a bit on the oily side. Use a soft brush and a rag seems to work best.
Old 09-13-2010, 01:09:51 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
Use Kerosene. Steam cleaners are WAY too harsh. Just kerosene and a soft rag. Keep soaking the stubborn stuff until it's soft enough to wipe away.
Old 09-13-2010, 01:17:18 AM
Roland Hayes Roland Hayes is offline
I have used paint stripper with surprising success to clean oil deposits etc. from wood and metal, the product that I have used is branded 'Nitromors' I don't know if you have that over there. The title on the can says 'kind to wood' cleaned everything up great, hose off with water after 15 minutes.
Old 09-13-2010, 06:08:21 AM
John Davis's Avatar
John Davis John Davis is offline
Use Dawn dish washing detergent cuts grease and oil real good. Then use heat lamps or lights to draw excess oil out of the wood.
Old 09-13-2010, 09:19:37 AM
Scott Barnes's Avatar
Scott Barnes Scott Barnes is offline
I keep a plastic spray bottle with a mix of kerosene and diesel next to my cleaning projects. Numerous squirts during the day and weeks will hydrate the cakes of crud and make physical removal simple. Works well for me.
Old 09-13-2010, 09:41:59 AM
Birddog58 Birddog58 is offline
If you are looking to pull the oil and grease out of the wood oven cleaner and you can buy a product called "whitining" from MIDWAY USA that will pull out the majority of it that has been soaked in the wood. I have used this method on a couple of guns I have restored that has gun oil and grease in the stock.
Cleaning steam4fun Steam Stationary Engines, Traction Engines 19 02-22-2007 08:58:53 AM
Cleaning a 15.0 JC bkahler Onan Generators 6 10-30-2006 10:27:17 PM
Cleaning Engine SteamGirlWard Steam Stationary Engines, Traction Engines 6 06-13-2006 10:12:28 AM
Carburetor Cleaning charlie allen Antique Engine Archives 4 04-29-2004 11:28:12 PM
Cleaning out old gas Norm Antique Engine Archives 2 01-16-2000 07:54:50 PM
