If there is an easier way
this thread has 6 replies and has been viewed 1285 times
Old 01-11-2004, 04:57:57 PM
Eric McKenna
Default If there is an easier way
Anybody make wood axles for the skeins that fit old iron wheels?? I am squaring off the dimensions and then will use a hand grinder to round them off..............red oak takes a long time to cut through!! I guess its a good winter project for the patient......only three more ends to go!
Old 01-11-2004, 05:42:09 PM
Peter Holmander
Default Re: If there is an easier way
That would be done with a bandsaw and a lathe or a tablesaw and then a lathe. Oak turns very nice. A good woodlathe man could do that job for you in about 20 minutes, especially if they were already cut down. You could also cut them down with a skilsaw with a good carbide blade,,,,then finish the end of the cut with a handsaw. If you go the skilsaw method,,,make sure you clamp them down, so when you're done, you have all your fingers left. Safety First! Good luck!!
Old 01-11-2004, 08:50:30 PM
Nick Stanley
If you didn't have a lathe, you could always whip out the drawshave. Checking your fit in the skeins each time by chalking the wood and turning it a few degrees each way and see where the chalk is rubbed off. Good Luck! -Nick
Old 01-12-2004, 12:59:32 AM
Are are SURE the skein is ROUND? Can't say I've seen a round one. They are usually oval shaped to prevent the skein from spinning on the axle. In addition, they are heated VERY hot and shrunk to the axle and then quenched so if it's done right, you'd better have have it right the first time. I have done it and I've heard that's also how they fit them: heated them up, checked the fit, scraped off the charred wood until it almost fit and then went in for the finish. Craig
Old 01-12-2004, 01:06:14 AM
Don C. Wiley
I'd go for a VERY sharp "draw knife" first and finish with a VERY sharp "spoke shave", for the final fit. The chalk or heated and chared would make for a perfect fit it you take your time. Sounds a lot like scraping a babbitt bearing.
I've got four to fit if I live that long. I never checked to see if they are oval instead of round, but it makes sense.
"DELCO DON" Southern Illinois
Old 01-12-2004, 10:45:37 AM
Patrick Marsh
Check out this web site. It is about building wooden wagons.
http://209.35.81.43/Current%20Projec...the%20Shop.htm
Old 01-13-2004, 07:01:16 PM
Eric McKenna
THANKS TO ALL THE "STACKERS" for the help and advise. I think this project is starting to come along pretty well, I am keeping a photo PLAY BY PLAY record of this project on my photoisland page and will make it available to those who are interested THANKS EVERYONE..and HARRY for this site!!
Easier way to get gas out of car tanks len k Onan Generators 26 01-23-2019 08:21:46 PM
Loading a little easier Brian.P Hit & Miss Gas Engine Discussion 9 06-07-2015 07:14:13 PM
Make pull start easier? 3shorts Antique Marine Engines and Outboard Motors 8 11-07-2014 05:42:27 AM
K-582 powered homelite, so much easier with the right tools armandh Generators & Electric Motors General Discussion 0 05-15-2014 05:12:38 PM
An easier way ? Dave Haning Antique Engine Archives 3 12-04-2002 12:41:29 PM
