Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Make pull start easier?
this thread has 8 replies and has been viewed 4588 times
Old 09-23-2014, 11:36:27 AM
3shorts 3shorts is offline
Default Make pull start easier?
My 1955 15HP Evinrude is a bear to pull start. Is there any way to make it easier? I'm bushed before I cast a line!
Old 09-23-2014, 12:27:17 PM
Default Re: Make pull start easier?
Remove the recoil and look at the sheave, is it round where the rope winds? The later motors used an oblong sheave and a pawl that was timed to catch when the engine was coming up on compression. This gave leverage to pull over compression and speed as it came off of compression, making it a steady easier pull. I don't know if this would be adaptable to your motor, would require the recoil and flywheel.
Old 09-23-2014, 09:42:26 PM
Any ideas on where to find out if this would work on my 55? where to get parts,? etc.
thanks for the idea.
Old 09-23-2014, 09:44:58 PM
Make sure the mag is good and strong, points are clean and gapped right, etc. Carb is set right, fuel fresh, on and on. If anything is a bit off your arm gets to compensate....
Old 09-23-2014, 10:58:42 PM
Steve A W Steve A W is offline
Go to the Antique Outboard Motor Collectors club website and post Your question on there "Ask A Member" forum.
If it can be done, They will know and probably give You part numbers also.
http://aomci.org/
Good Luck with Your motor.
Steve A W
Old 09-24-2014, 09:58:17 AM
My 55 Evinrude runs like a top, once I get it running. The problem is that it is hard to pull. I won't be paying $50.00 to ask my question. Thanks anyway for the tip.
Old 09-25-2014, 02:18:49 PM
3Shorts
The $50 is a 2yr membership to the club, the forum is free.Here's a direct link to the Ask A Member help forum;
http://www.aomci.org/cgi-bin/yabb2/Y...ard=askamember
Steve A W
Old 11-07-2014, 04:52:22 AM
Ralph D Simmons Ralph D Simmons is offline
Steve ,
Try Discout Marine up in Port Byron N.Y.
(315) 776-8778 wayne Murray owner
older outboards are therespeciality
I use this people a lot
thank you ralph simmons
ralph292@verizon.net
clyde ny
Old 11-07-2014, 05:42:27 AM
Two methods come to mind. Easiest is to add longer pull rope if there is room. As the rope is wound on the recoil, it increases ratio and thus the leverage on the first part of the pull.
The second is a modification of the valves, that you may not want to do.
Before the trick of a moving pall compression release on the cam, Briggs & Stratton used to grind a nick on one edge of their exhaust valves that served as a compression release, but only had minor effect upon engine performance at higher RPM. Perhaps too drastic to try on a good running engine. But maybe something to consider if you could obtain an extra valve to compare performance effects with. I only saw the nicked valve trick used on small one cylinder engines.
Doc
Onan CCK-5.0 pull start change to elec start roundrockcrawler Onan Generators 29 08-07-2012 10:26:03 PM
Pull start reinstall Johnnyboy Small Air Cooled Gasoline Engines 4 01-09-2011 05:11:00 PM
Rumely Oil Pull 20-40 Start and Run Chris Props YouTube Old Iron Videos 20 03-19-2009 06:52:01 PM
Hobart G-225- How to make dial turn easier? Add Electric start to Wisc. engine? rebsar Welding Shop 6 12-07-2008 08:35:07 AM
Does propane start easier than natural gas? Frank Stenger Oil Field Engines & Related Equipment 9 08-23-2007 08:53:21 AM
