An easier way ?
this thread has 3 replies and has been viewed 1199 times
Old 12-03-2002, 10:12:43 PM
Dave Haning
Default An easier way ?
Something wonderful is happening to my engines! As I get older they're gaining compression! Don't know why or how this is happening but I'm finding it harder to pull my 7hp Herc and 6hp FBM through. Not too long ago it seems there was a discussion on bounce starting. Can someone shed a little light on this for me? Seems like this might be a little easier. Thanks, Dave--
Old 12-04-2002, 10:18:15 AM
Bob Brown
Default Re: An easier way ?
I have a 5 h.p. Jeager that I start by pulling it back against compression. You have to pull it through to choke it and suck the gas into it and then I just bounce it back against compression hard enough to trip the mag and it usually starts right up. Do not retard the timing if there is a retard lever. You will just have to pull it harder if you do. Good luck. Bob Brown
Old 12-04-2002, 10:40:06 AM
John R.
Dave, I start my 8-HP Sparta by holding the exhaust valve open with my left hand while turning the flywheel with my right hand. Just a few degrees before top dead center, I let go of the rocker arm thats holding the exhaust valve open, and it fires right up. You may need to prime the cylinder first. It takes a little practice, but what does'nt. Have fun!
Old 12-04-2002, 12:41:29 PM
Joe Morris
Both Bob and John have the right idea. I might add that the reason for leaving the spark advance lever in advanced position is that some times when bounceing back you have to bounce it back so hard to get it to trip that sometimes it will go over the wrong way I/E on through top dead center. I have a six horse Fairbanks H that I start by pulling it through one intake stroke to prime it then use the method discribed by holding the intake until near T.D.C. then push it on over and it is running. Neither of these methods work too well unless the engine has good compression.
Easier way to get gas out of car tanks len k Onan Generators 26 01-23-2019 08:21:46 PM
Loading a little easier Brian.P Hit & Miss Gas Engine Discussion 9 06-07-2015 07:14:13 PM
Make pull start easier? 3shorts Antique Marine Engines and Outboard Motors 8 11-07-2014 05:42:27 AM
K-582 powered homelite, so much easier with the right tools armandh Generators & Electric Motors General Discussion 0 05-15-2014 05:12:38 PM
If there is an easier way Eric McKenna Antique Engine Archives 6 01-13-2004 07:01:16 PM
