Posts Not Showing Up?
this thread has 3 replies and has been viewed 2046 times
Old 04-02-2003, 01:37:12 PM
Hank Czerwick
Default Posts Not Showing Up?
Ok, over the last week or so I've posted twice and my posts don't show up. Is this happening to anyone else? I posted a follow up to my grease gun posting, it's not there, and I also posted a question about United paint colors, it's not there. One of these posts was from Home (Linux) and the other was from Work (Win 2000).
Old 04-02-2003, 09:55:45 PM
Harry's Avatar
Images: 316
Default Re: Posts Not Showing Up?
Thank you for pointing this out. I'm the one that you should normally direct this question to, but in this case, there was no reason for me to remove your posts. Believe me, I do remove posts on occasion and there's no doubt in my mind that I would know your name if I did so. However, your name is not burned into my memory and therefore, I have not removed any of your posts.
I will investigate the situation. -- Harry
Old 04-02-2003, 10:07:02 PM
Harry's Avatar
Images: 316
Go to the link below and enter your name. I found 13 posts. Are they all there?
http://www.enginads.com/extras/search.htm
Old 04-03-2003, 11:03:11 PM
Hank Czerwick
Yep, they are all there. Thanks
Hank
Just showing off some goods! Temple2426 Antique Gas Engine Discussion 7 12-28-2010 09:57:04 AM
My first showing afretired Oil Field Engines & Related Equipment 16 09-30-2010 01:16:47 PM
Just showing off David Babcock Antique Gas Engine Discussion 9 10-16-2009 12:53:06 PM
First showing Rag Antique Gas Engine Discussion 2 04-27-2009 05:36:02 PM
