12HP Bessie running on propane with simple setup.
this thread has 5 replies and has been viewed 1169 times
Old 05-24-2017, 06:12:41 PM
Sekiar Sekiar is offline
Exclamation 12HP Bessie running on propane with simple setup.
Yesterday I simplified my gas control setup for my 12HP Bessie and it now starts and runs much better. I added a multi-turn gas control valve in line with the main gas valve, which allows a much easier speed control, especially for slow running. Also now have the hot tube gas input as another input. Now the original single or actually a 1/2 turn valve is used as an on and off gas control. Anyway I'm still learning and just wanted to share my fun experience playing with my toys
https://www.youtube.com/watch?v=mmSO...ature=youtu.be
Name:	Bessie 12hp 5-24-17 005.JPG
ID:	282794   Click image for larger version
Name:	Bessie 12hp 5-24-17 002.JPG
The Following User Says Thank You to Sekiar For This Post:
Old 05-24-2017, 07:17:04 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Default Re: 12HP Bessie running on propane with simple setup.
You can also slow it down by adding more air to mix
---------- Post added at 07:17:04 PM ---------- Previous post was at 07:15:59 PM ----------
What is serial number for it. I can get the shipping card for it.
Do i really look like a people person?
Old 05-24-2017, 11:09:46 PM
I do have a ball valve in the air intake, and Tom thanks for the data you gave me on this engine several month ago. Thanks to you I have a copy of the shipping card and is dated 1909. This is turning out to be one of my favorite fun engines now that it's tamed and runs to suit.
Old 05-25-2017, 07:44:55 AM
David A. David A. is offline
great job, looks good and runs better, I like your fuel set up
Old 05-25-2017, 09:01:29 AM
Tom Geier's Avatar
Gate valve is what you want. Ball valve is hard to set same ever time. Gate valve you can count turns to get it the same
Old 05-25-2017, 11:32:10 AM
Tom I agree on using a gate valve, as I have on my Reid, however for some reason the Bessie seems less picky about the air intake setting since I've installed the multi-turn gas valve. Just a good reason to keep on playing.
Simple forced air propane burner ferroman Blacksmithing and Metallurgy 0 04-14-2015 11:30:29 PM
homemade propane setup c east Generators & Electric Motors General Discussion 2 08-18-2011 09:19:10 AM
Propane Regulator setup help needed. Frankiec Generators & Electric Motors General Discussion 18 12-15-2009 10:29:14 PM
Propane setup for 7.5MMK62 rlc1 Kohler Generators 5 11-09-2009 04:49:25 PM
