Does anyone know what these mags were used on?
this thread has 9 replies and has been viewed 574 times
Old 06-06-2019, 07:47:16 AM
TomBall TomBall is offline
Default Does anyone know what these mags were used on?
Does anyone know what these mags were used on? One is a Dixie M1 with flat base. The other is a Fairbanks RV 4 cylinder mag on what appears to be a conversion bracket.
ID:	336503   Click image for larger version
ID:	336504   Click image for larger version
ID:	336505   Click image for larger version
Old 06-06-2019, 10:17:05 AM
Default Re: mag uses
Tom, does any of the brass appear it may have been nickel plated? On the dixie,
Old 06-06-2019, 10:34:15 AM
Dan Baalman Dan Baalman is offline
I think the RV4 went on a Fordson tractor, and Dixie might go to Cushman engine.
Old 06-06-2019, 11:37:32 AM
I would say the Dixie was on a Fuller pump engin but was also used on Indian as well as othr motorcycles.
Old 06-06-2019, 11:52:10 AM
I've got a 1919 Indian Light Twin Engine, uses a dixie Single. Mine was rotten. End covers were nickel plated. It had ball bearings in it. I found a similar mag but it was brass bushed and the gear end armature didn't extend out as long as the original one with bearings, so, I'm still sorta looking.
Old 06-06-2019, 12:44:25 PM
I will clean the Dixie and see if I can find any nickel plating. I tried it and it produces spark. It has a advance lever for timing.
Old 06-06-2019, 01:11:52 PM
Default Re: Does anyone know what these mags were used on?
That aluminum base on yours is like mine. Mine measures 3-1/4" from center hole to center hole. And are for 1/4" bolts. Measure that also
Old 06-06-2019, 03:57:49 PM
Pat, the bolt holes on this one are 3 inches center to center one way and 4 7/16 the other. I could not find any nickel plating. The other mag is a Fordson set up. I looked at one that had the same bracket but different mag. Was this a conversion on the early ones or factory.
The Following User Says Thank You to TomBall For This Post:
Old 06-06-2019, 06:13:04 PM
Lonnie Grissom Lonnie Grissom is offline
Thanks tom for posting pictures of thr Dixie mags. I have two of them. One is 4 cyl and one is 2 cyl. I sorta know what they were used on.
Old 06-06-2019, 06:13:09 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Like most accessories on the Fordson, they are all aftermarket by out side vendors.
What do these Mags fit? Will Batty Magnetos, Ignition Coils and Spark Plugs 4 10-20-2011 03:34:17 AM
need ID on these 2 mags Brian.P Hit & Miss Gas Engine Discussion 1 07-10-2011 11:28:14 PM
How many different mags? KyleBlankenship Hit & Miss Gas Engine Discussion 1 04-06-2010 04:13:38 AM
What do these mags fit? snowcountryfarmer Magnetos, Ignition Coils and Spark Plugs 1 12-07-2008 04:49:04 AM
Are FM J mags the same a Lucas RS1 mags Adam Antique Engine Archives 0 12-15-2001 03:08:28 AM
