Ronaldson and Tippett Type N Magneto Coupling and Timing
this thread has 52 replies and has been viewed 2507 times
Old 01-26-2019, 12:40:14 AM
cobbadog cobbadog is offline
Default Re: Ronaldson and Tippett Type N Magneto Coupling and Timing
Great news about it now working and it is a shock that you don't want to get too often but it is a pleasing result.
It usually is something simple that goes wrong and a bad connection is just one of them. Look forward to the fuel system being sorted.
Old 01-26-2019, 01:08:43 AM
Pollardd Pollardd is offline
Here is a picture of what the Magneto looks like inside.
Just in case you were wondering
The Following User Says Thank You to Pollardd For This Post:
  #43
Old 02-24-2019, 07:23:35 PM
Hi Guys,
I managed to clean out the fuel tank. There was all manner of rust in there.
Cleaned out the carby and put it all back together.
Fuel in, Oil in, I gave it two cranks and it started. i couldn't believe it.
The little knob to adjust the mixture is missing a little friction thing so it moves around with the vibration but other than that I think it is a goer
Here is a picture of where I put the timing marks.
I'll stamp them in the flywheel later.
Here it is all together
And of course the mandatory video
https://www.youtube.com/watch?v=muRO1hUx4iA
Now I just have to think up something for it to do.
Thanks again for all your comments and assistance.
David
The Following 2 Users Say Thank You to Pollardd For This Post:
  #44
Old 02-24-2019, 08:15:40 PM
AussieIron AussieIron is offline
I don't have an N type anymore,so I can't look, but I think there was a short coil spring under mixture screw head to stop it turning. Hope my memory is ok on that. Good to see you got it going. Good feeling isn't it? -Neil.
Old 02-24-2019, 08:52:34 PM
I did find the little hole and there is a half a spring still in there.
So your memory is still good!
I thought it may have a pin on top of the spring that contacts the underside of the knob and gets fired out when you remove the knob. I have a repo manual and it has an exploded view and a parts list and that spring/hole is not shown. It actually has a larger spring around the shaft of the fuel mixture knob.
There is like a row of ratchet groves on the underneath of the knob for something to contact. If there is enough travel on what is left of the spring and enough clear section on the hole I'll make a little pin. with a domed head.
I thought I would be dicking with stuff for weeks trying to get it to start. I couldn't believe when it started first go with only two cranks of the handle.
Once I get the mixture know sorted I'll fill the cooling tank with water and let it run for a while then check the compression again.
Old 02-24-2019, 09:03:18 PM
Hi Team,
Aussieiron is correct in that there is a small coil spring, R&T Part No (V-304) under the needle valve wheel to stop movement during operation.
Hope this helps.
Cheers,
Eddie B.
Name:	N Type Parts Pic.jpg
ID:	329366   Click image for larger version
Name:	N Type Parts List.jpg
Old 03-03-2019, 06:46:25 AM
My engine has another blind hole next to the hole the mixture screw goes in.
There was a little spring down the hole that I have subsequently lost.
I made a little pin that fits in the hole and found a spring that sits nicely around the pin.
Now when I screw the mixture screw down the head of the pin rubs against the creations under the head of the mixture knob. It holds it in place nicely. If it wasnít made this way originally perhaps it should have been
  #48
Old 06-07-2019, 02:52:32 AM
WEST AUSSIE WEST AUSSIE is offline
Location: Perth, Western Australia / Kingscliff, NSW, Australia
Hi Guys
How do you time the magneto to the engine ? I removed the coupling and thought it had a keyway in it . I had it anodised for looks and now want to refit it .
---------- Post added at 01:52:32 AM ---------- Previous post was at 01:49:01 AM ----------
Sorry it is a Lucas SR with the single male tip on the coupling .
Old 06-07-2019, 03:07:25 AM
Hi West Aussie,
I managed to find the Owners Manual that described the process very long windedly in text. (no pictures)
I had to pay a couple of bucks for it and it was quite handy to have the full thing with exploded parts views and other adjustments required to disassemble / reassemble. I can find and scan the timing section for you if you need it.
There should be a couple of timing marks on the Fly Wheel, one for TDC and one for Spark. And another mark on the crank case to line them up with. Mine was missing all these marks and I had to figure out where they should go. I seem to remember we discussed these problems on this thread so be sure to read it end to end.
Let me know if you want me to scan you a bit of the manual that discusses the timing. I'm sure it's no longer in copy write. I didn't mind paying a few bucks for it as that guy that has them did a nice job of reproducing it.
David
Old 06-07-2019, 04:20:24 AM
Thanks David
Mine has all the marks on the flywheel and block , the main thing is does the manual tell how to install the coupling to the magneto , I'm assuming there must be a certain position that it sits on the shaft were the male tip meets its partner on the engine . If you could scan that section that would be great thanks .
Old 06-07-2019, 05:20:13 AM
Yes the manual describes the process.
There are no physical keys or stops to find.
Iíll find the details for you tomorrow.
Off the top of my head the tapered shaft is Locked in position when the breaker points just start to open and the spark mark on the fly wheel lines up with the line on the block.
You need to maintain a little bit of free play on the magneto coupler through one full revolution when locking down the magneto mounting bolts so you donít wear out the magneto bearings.
  #52
Old 06-07-2019, 07:03:58 PM
Here is the bit about installing the Magneto.
The book is about 70 pages and has everything you would need to know about disassembling and reassembling one of these.
I got it from a place named Rally Badges
It says something when they don't have a web address or email on their contact details which are printed on the back of the manual. I did a quick Google and they are here.
http://www.rallybadges.com/
They also do a book on the Lucas SR Magnetos. I didn't actually need it because the Magneto I have had just been fully serviced.
Let us know how you go
  #53
Old 06-10-2019, 01:47:17 AM
Thanks David
Will print it off and give it a crack .... Cheers
Ronaldson-Tippett Type N Engine Pollardd Hit & Miss Gas Engine Discussion 12 02-27-2019 06:36:24 AM
Ronaldson Tippett N Type cylinder liner ozbennett Smokstak Down Under 5 11-28-2016 10:53:25 PM
Ronaldson Tippett Type O jayvee Smokstak Down Under 9 05-31-2015 05:09:44 PM
What magneto do I need for a Ronaldson-Tippett type N? farnzy Magnetos, Ignition Coils and Spark Plugs 2 03-01-2013 03:54:26 AM
Ronaldson Tippett Type O jayvee Smokstak Down Under 0 11-10-2012 11:50:29 PM
