Go Back   SmokStak > SmokStak® General Discussion > The Junque Drawer
The Junque Drawer Excess tools, parts or books that might be rare and that someone else might need. This is NOT a buy and sell forum.
The Junque Drawer
Tubing roller
this thread has 11 replies and has been viewed 1349 times
Old 10-24-2018, 04:21:35 PM
rknarr2 rknarr2 is offline
Default Tubing roller
Hi,
I found these 2 things in an outbuilding. I think they are tubing rollers but I am not really sure. The tops are 5 1/16" long and the bottoms are 4 1/4" long. The sides are 2 1/8". The thickness is 1/2". The wheels are 2 1/2" in diameter and 3/8" thick. The bolts on top are 3 3/8" apart and the bolts are 9/16". Thank you for assisting me in these.
Regards,
rknarr2
ID:	321418   Click image for larger version
ID:	321419   Click image for larger version
ID:	321420   Click image for larger version
Old 10-24-2018, 08:49:28 PM
DaveMisch DaveMisch is offline
Default Re: Tubing roller
These are not rollers to expand a tube in a boiler. I don't know what they are for.
The Following User Says Thank You to DaveMisch For This Post:
Old 10-24-2018, 09:10:33 PM
PFT's Avatar
PFT PFT is offline
They could be used to support round stock and tubing that is being rotated as in a lathe or pipe threader. They look heavier duty than necessary, but they did build things better back then.
PT
The Following User Says Thank You to PFT For This Post:
Old 10-25-2018, 12:09:42 PM
My brother in law thought this was to roll pipe or tubing over as you lengthen it. I wonder if it might have been used for sucker oil tubing or oil pipes. Thank you for your assistance in this matter.
rknarr2
Old 07-15-2019, 10:55:31 PM
Kothe Kothe is offline
I have seen old grinding wheels ( sandstone variety ) that use these to support the shaft that the stone is mounted on
Old 07-16-2019, 09:14:19 AM
PT
I was going to guess they were use by a welder, for welding pipe, so they could support and rotate the pipe.
Old 07-16-2019, 09:29:31 AM
Tracy T Tracy T is offline
I think you may be right! If thats the case there should be another set to go along with this set.
Old 07-24-2019, 12:27:57 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
I have a much smaller version of these that is intended to check a shaft for straightness or balance. You rotate the shaft & check with an indicator. The pins on the bases look like they would locate the rollers on a bench or other support. They might be for working on line shaft setups??
The Following User Says Thank You to Jack Innes For This Post:
Old 07-24-2019, 06:00:05 PM
AussieIron AussieIron is offline
Why couldn't they be sliding door top rollers for a big sliding door?
Old 07-24-2019, 06:29:10 PM
I cant help with what it is but I got one just like it around here somewhere.
Old 07-31-2019, 03:44:20 PM
I suppose you could make them work that way, but two reasons I don't think that was their original use.
1) no need for the V notch in the center of the side plates for that application
2) the "pins" on the top don't look to be threaded to attach to an angle plate to hang the door from.
Old 09-11-2019, 06:26:11 AM
AugerCreek AugerCreek is offline
We used a set like that as balancing rollers for any thing that rotated and needed balancing.
Bending Tubing Help! JFred Machine Shop and Tool Talk 12 06-10-2014 03:08:25 PM
Gas Line Tubing Barn Bikes Small Air Cooled Gasoline Engines 3 03-26-2011 05:47:58 PM
Brass Tubing Dusty Scale Model Engineering 7 11-26-2010 11:48:37 PM
Tubing benders Ray Cardoza Hit & Miss Gas Engine Discussion 13 11-06-2008 09:47:10 PM
