Smokstak Down Under
What Parts Do You Need?
this thread has 207 replies and has been viewed 26599 times
Old 10-26-2018, 12:38:42 AM
cobbadog cobbadog is offline
Default Re: What parts do you need?
G'Day John,
Try Ozlisteroid for a crank handle. They list one or two sizes but measure the diameter of the crank shaft so you know what one you need. I had to get one made to suit the 2 1/2" crank shaft on the CD Lister.
Old 10-28-2018, 03:11:32 AM
john gilbert john gilbert is offline
Thanks for that info Cobba, will do. Cheers, John
Old 04-20-2019, 11:07:39 PM
Mike McKnight Mike McKnight is offline
Question Re: What parts do you need?
I think I have heard that a good many IHC Titan throttlers made it down under, would anyone know where I could find a carb/mixer for an 8 HP Titan? I have the brass bowl, but need the cast iron part that bolts to the head. Have had NO luck finding one here in the States!
Thanks,
Mike M
Old 04-28-2019, 02:58:59 AM
macdonald macdonald is offline
hi i have a yc stover and am looking for a fuel pump and lever, igniter and magy,breather side plate and carby or drawings with sizes to make then thanks leigh (hens teeth might be easier)
Old 04-28-2019, 06:59:34 PM
RustyNumbat RustyNumbat is offline
Need a starter motor to suit a Chamberlain 9g!
Old 05-10-2019, 05:36:20 PM
gozoish gozoish is offline
good evening everyone,
i need a crank oil ring for a ruston hornsby 2 yhr because the one i have is badly damaged and had previous repairs.
thank you all
david
Old 05-13-2019, 05:25:09 PM
rodeo41 rodeo41 is offline
Default Re: What Parts Do You Need?
Looking for a good head with valves for a Stover KF engine.
Please email me at rodeo59@comcast.net as I am not always on here. I am in Pennsylvania, USA
Old 05-13-2019, 06:00:09 PM
Dobbo56 Dobbo56 is offline
Hi looking for crank handle and exhaust rocker arm for IHC 3 M 3.5hp
Dobbo56
Old 05-13-2019, 06:13:44 PM
isandian isandian is offline
I have one here, which was replaced by an aftermarket one when it became lazy. You are welcome to it except it is in the Sydney area.
Ian
Old 05-14-2019, 12:54:22 PM
MaxLeggett MaxLeggett is offline
Default Re: Capel LBV 5hp
Originally Posted by MaxLeggett View Post
Commenced fixing up Capel engine. Need carby inlet pipe work and associated bits, (only have carby) water jacket head, exhaust pipe work and muffler, fuel tank, crank handle. Probably more as I get going / learn more.
Thanks
Max
Found all I need here in WA. Twist in the story is my engine now gone to new owner and hopefully engine up and running very soon.
Old 05-15-2019, 04:32:26 PM
Dennis Wheelhouse Dennis Wheelhouse is offline
Hrllo.
Has anybody got an air valve assembly for my Hart Parr 20 carburettor (dx245) please.
Also looking for air inlet assembly for my X model Rumley Oil Pull. I lost it when tractor was on the truck.
Thanking you
Dennis W
Old 06-06-2019, 08:49:24 PM
mflorian mflorian is offline
I need a head for a 4.5 hp Sandwich engine
Old 06-06-2019, 11:43:31 PM
Benno Benno is offline
Hi All,
Looking for anything Lister, CS Diesel A/B Junior L / J Petrol around the Dubbo area. All parts, chasing fuel tanks, cylinders, Heads. I'm open to swaps if you need anything and I have it & vice versa, Will travel. Will consider complete or incomplete engines. Thankyou
---------- Post added at 10:38:55 PM ---------- Previous post was at 10:29:22 PM ----------
Originally Posted by Listerddan View Post
2.25 inch lister CS bigend bearing OR lister CS 2.5 crank.
Door into barrel cooling gallery, lister CS not fuel pump side one the exhaust side one.
Go to Old Timer Engines Australia, there are brand new repros available.
---------- Post added at 10:43:31 PM ---------- Previous post was at 10:38:55 PM ----------
Good luck with that one Slugga - I'm having a hard time just sourcing the rings for one of these!
Old 06-30-2019, 12:49:05 PM
ENGINEBOY ENGINEBOY is offline
Hi did you get a bigend for your Blackstone regards
Opencrank.com
Jason tysoe
Old 07-06-2019, 04:33:19 AM
muzzery muzzery is offline
[QUOTE=harrone;1517095]Are you still after a YB hopper?[
Harrone, yes Im still looking. I have also pmd you. Sorry about the delayed reply
Murray
Old 07-08-2019, 01:22:13 PM
Default Re:Hornsby bracket
Hello I am in need of a Hornsby bracket for the sideshaft it will have a cast stamp number on it of x20
Please get I touch if you have one please
Old 08-08-2019, 09:46:10 PM
Jeff Taylor Jeff Taylor is offline
Looking for a head and mag bracket (9013k?) for a Stover 2hp KA with a Wico EK mag.
Old 08-09-2019, 02:41:09 AM
G'day Benno,
Make contact with Rob.S. He is in Molong when not travelling around Oz and has a paddock full of cast iron.
Rob is a member here so look him up and send a PM.
Old 08-18-2019, 06:27:53 AM
Vizer Vizer is offline
Hi All,
Looking for A2 Olds cylinder and piston.
Also looking for parts for Simplicity 6hp engine, rocker arm stand.
Thanks Levi.
Old 08-19-2019, 02:09:17 AM
Originally Posted by Benno View Post
Hi All,
Hi Benno,
I just got news that there is an auction this coming Saturday 24/8/19 at 177 Bushland Dr, Yarrevell, near Kempsey NSW on the list is 7 Listers a HB2, SR3, CE, CS, and LD1 as a genset.
Contact number of the seller is 0408 607 896.
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Hit & Miss Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Hit & Miss Gas Engine Discussion 8 03-16-2013 11:52:47 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
