Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Fairbanks Morse Y Style H Air Start
this thread has 1 replies and has been viewed 1663 times
Old 09-03-2013, 10:27:28 AM
huberman huberman is offline
Default Fairbanks Morse Y Style H Air Start
I have the 10, 15, 20 and 25 horse Fairbanks Morse Y style H. This weekend we got the 25 horse running. It had not ran for some time. We had to belt it up to get it started. I have read and understand the starting procedure Harry has posted. Thank Harry it is very well written.
My 10 and 15 horse engines were being air started when I bought them. It appears they had the air inlet where the pressure relief valve is on my other two engines. Is this correct way to have the air start set up? If so, what is the proper procedure for using air start with these engines?
I would like to set the other two engines up for air start as well. I know air start is for wimps but I am getting older. What is the best way to setup air start on these engines?
The Following 2 Users Say Thank You to huberman For This Post:
Old 09-03-2013, 03:01:04 PM
Ken Majeski's Avatar
Default Re: Fairbanks Morse Y Style H Air Start
My 15 HP Y was hooked up for air start when I got it. The air start valve was just T'ed into the compression release port.
I found that the inrush of Cold air didn't help for starting. So I took it off.
We've discused this Many times but most hard starting is caused by using too little heat and too concentrated heat.
I'm 71 now and yes it is this easy. A friend has a 25 and I also start his only difference is it is a little harder to overcome the friction and inertia of the heavy flywheels.
This was a 50 degree day after it had set all winter.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Fairbanks Morse Z Style C 3hp Mag?? drf24 Magnetos, Ignition Coils and Spark Plugs 7 10-21-2012 05:38:20 PM
Fairbanks Morse Z style C mave diller Hit & Miss Gas Engine Discussion 1 03-05-2012 10:56:01 AM
Fairbanks Morse Z Style? Enar Drugge Hit & Miss Gas Engine Discussion 18 11-10-2010 01:27:40 AM
Value of a Fairbanks Morse Z Style C MSimons Hit & Miss Gas Engine Discussion 4 04-20-2009 01:25:04 PM
Fairbanks Morse Z Style D Harry Antique Engine Archives 11 04-30-2001 11:26:31 PM
