Oil Field Engines
4Hp Vertical Oil Well Supply info wanted
this thread has 4 replies and has been viewed 2452 times
Old 06-13-2014, 12:42:11 PM
Scott Hosack Scott Hosack is offline
Default 4Hp Vertical Oil Well Supply info wanted
Hello,
Does anyone have any information on the 4Hp vertical air cooled OWS engines. I am looking for any information on the company and this style of engine in particular. I have not been able to find much info at all. Anything would be greatly appreciated.
Name:	Oil Well Supply 001.jpg
ID:	197818   Click image for larger version
Name:	Oil Well Supply 007.jpg
ID:	197819   Click image for larger version
Name:	Oil Well Supply 005.jpg
ID:	197820   Click image for larger version
Name:	Oil Well Supply 006.jpg
The Following 4 Users Say Thank You to Scott Hosack For This Post:
Old 06-13-2014, 08:14:29 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Default Re: 4Hp Vertical Oil Well Supply info wanted
Yeah Scott, I've looked high and low on line and have struck out. All I've found are pages in OWSC catalogs. They have traits of Myrick and Bovaird and Seyfang but are unique. Seen several with broken crank cases.... Mine has a factory Wico R1 drive. I wonder if there is any info to be had. There is a nice one in the museum in Oil City down the road from the old ARACO factory on Seneca St.
The Following 2 Users Say Thank You to PaulGray For This Post:
Old 06-23-2014, 11:02:34 PM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
Other than the catalog, this is the only paperwork I have on it.
ID:	198509   Click image for larger version
ID:	198510   Click image for larger version
ID:	198511   Click image for larger version
The Following 4 Users Say Thank You to Chris Austin For This Post:
Old 06-23-2014, 11:09:50 PM
One more pic. Also interesting they advertise electric driven pump jacks, and also Novo powered pump jacks.I was told years ago they only built the vertical engine for a couple of years, but I don't have enough catalogs to prove this.
The Following 3 Users Say Thank You to Chris Austin For This Post:
Old 11-09-2014, 09:15:38 PM
Still looking for any information that I can get on the vertical Oil Well Supply engine. So far the only thing that I have found is for the horizontal engines. If anyone has a catalog, brochure, or pamphlet on the 4Hp air cooled vertical I would like to get a good copy of it. Thanks
Ideal vertical almost ready.....info wanted Eric McKenna Hit & Miss Gas Engine Discussion 3 09-04-2013 06:59:14 AM
Holland Vertical Engine Info wanted Rustaholic Hit & Miss Gas Engine Discussion 2 04-19-2011 01:27:49 PM
Wanted Gardner vertical info on V model burnoil Smokstak Down Under 3 03-01-2010 04:41:27 AM
RE/OLDS Ideal Vertical Info wanted Kevin Kusel Hit & Miss Gas Engine Discussion 2 05-05-2009 07:29:54 PM
info wanted:2 1/2 hp samson vertical Manuel Azevedo Hit & Miss Gas Engine Discussion 0 07-20-2005 02:01:14 AM
