Oil Field Engines
Shaft Mouse
this thread has 4 replies and has been viewed 2942 times
Old 07-20-2014, 08:13:13 PM
Fred Van Hook's Avatar
Fred Van Hook Fred Van Hook is online now
Photo Shaft Mouse
The Farmers 25 H.P. Superior oil field engine with shaft mouse. Well that is what I call it? Makes for good conversation!!
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
The Following 14 Users Say Thank You to Fred Van Hook For This Post:
Old 08-08-2014, 05:30:24 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default Re: Shaft Mouse
What is the purpose of the shaft "mouse" ? Thanks!
Old 08-08-2014, 06:19:19 PM
KeithW's Avatar
KeithW KeithW is offline
Helps keep dirt from collecting on the shaft and spreads the oil around.
The Following 2 Users Say Thank You to KeithW For This Post:
Old 08-08-2014, 09:58:49 PM
DieselAddicted DieselAddicted is offline
Back when equipment was run by line shafts hung from the ceiling the purpose was to keep the shafting polished so if the belt slipped and came off the pulley it would not wrap the shaft and either take the equipment to the ceiling,, or bring the line shaft to the floor. Secondary effect was it made certain bearing and pulley changes much easier due to the shaft being kept clean.
The Following 2 Users Say Thank You to DieselAddicted For This Post:
Old 09-11-2014, 08:11:13 PM
Mike Patterson Mike Patterson is offline
I just came across this (I've got a small line shaft in my shop and have been wanting to put a couple of rings on it between the pulleys).
I guess the technical name is a shaft-wiping ring.......a version of it was even patented !!!
http://www.google.com/patents/US1086458
The Following 3 Users Say Thank You to Mike Patterson For This Post:
Converting A Vertical Shaft Lawnmower engine to a horizontal shaft Jordan Garden Tractors and Mowers 18 06-16-2009 03:49:11 PM
Cleaning Mouse Mess out of a Hol-Gar 18.75 KW Gene O. Carpenter Kohler Generators 13 05-26-2009 09:40:17 PM
Mouse in the shop Bruce Sutton Antique Engine Archives 3 01-02-2004 10:17:56 PM
