Oil Field Engines
Alten s-6 pump jack
this thread has 2 replies and has been viewed 1714 times
Old 08-23-2014, 10:41:57 AM
rigger69 rigger69 is offline
Default Alten s-6 pump jack
I have a Alten pump jack in great condition. What is a good electric motor to make it run? I have been told 1hp or less with no load. Also the rpms? At Portland I was told that the jack operates at 8-10 strokes per minute. Thanks
Old 08-25-2014, 04:07:44 PM
Reed Engine's Avatar
Default Re: Alten s-6 pump jack
If this is for display only you will probably need to remove the weights so it will roll free. You should be able to roll it through its entire stroke by hand. Be careful and not cut a finger off doing it though. If it will roll by hand a 1 hp motor should be fine. Go to a local motor shop and tell them what you want to do I'm sure they can fix you up. Only recommendation I have is rain proof.
Old 08-31-2014, 12:45:56 PM
I bought a 1hp electric motor with a 2 inch pulley, along with a 88 inch l4 v belt. Runs great! Now I just need the pump rod stuff to attach to the horse head.
The Following User Says Thank You to rigger69 For This Post:
Alten pumping unit Reed Engine Oil Field Engines & Related Equipment 5 10-26-2013 07:52:09 AM
Stover Pump Jack Pump Questions gregguy Farm Antiques and Collectibles 1 05-24-2012 12:55:18 PM
U.S. Wind Engine & Pump Co. Pump Jack Keith Thomas Farm Antiques and Collectibles 7 11-30-2011 05:19:34 PM
pump question myers pump and jack BobM Hit & Miss Gas Engine Discussion 1 08-17-2009 02:10:58 PM
Ebay find,Monitor Pump Jack engine complete with pump and arms Benny Mckheean eBay© Auction Discussion 1 09-02-2005 06:27:14 PM
