Oil Field Engines
Need help, rated HP @ rpm of FM engines.
this thread has 2 replies and has been viewed 1338 times
Old 10-07-2014, 06:34:28 PM
Reed Engine's Avatar
Default Need help, rated HP @ rpm of FM engines.
I need to know the exact rated HP at max RPM of all FM engines from 118 to 503. If there is a link to this in some original pamplet it would be nice. This is for EPA requirements so the more "official" it is the better.
Old 10-08-2014, 02:27:59 PM
Doug Waggonner's Avatar
Default Re: Need help, rated HP @ rpm of FM engines.
of page 64. of the FM book it had the engine spec chart showing rated HP & RPM.
This what you're looking for? in PDF is says page 34.
http://www.arrowengine.com/en/litera...-morse-sup-sup
Old 10-08-2014, 06:51:10 PM
Doug, I called Bill Yarbrough and he gave me what I was needing. He still remembered from his days with Bell Manufactoring.
The arrow chart I looked at had the 346 rated at 375 rpm max. I understand that to be incorrect, Bill says its 525 just like the 503.
Hit n Miss RPM - How is it rated? Zira Hit & Miss Gas Engine Discussion 5 07-23-2010 04:22:28 PM
Real Working Engines rated under 1 horsepower Denis Rouleau Hit & Miss Gas Engine Discussion 20 10-20-2008 03:30:19 PM
IHC LA rated r.p.m.? Scott Kocher Hit & Miss Gas Engine Discussion 1 12-20-2007 04:17:52 PM
20 or 22.5 bessemer rated rpm? DirtbikePilot Oil Field Engines & Related Equipment 2 02-01-2007 03:15:23 PM
How are winches rated? Mark T Antique Engine Archives 9 07-26-2003 12:09:47 AM
