Oil Field Engines
Reid popoff valve
this thread has 7 replies and has been viewed 2628 times
Old 10-11-2014, 04:17:27 PM
Dustin D Ehli Dustin D Ehli is offline
Default Reid popoff valve
Hey,
is there any reason why this would not work as a charging cylinder relief valve on a 15 hp reid.
http://www.grainger.com/product/APOL...ef-Valve-3EEY2
im just assuming its cheaper that finding an original one.
Having a blast preserving the past.
My Youtube Channel
Old 10-11-2014, 07:02:55 PM
Reed Engine's Avatar
Default Re: Reid popoff valve
Has a rubber seat in it (EPDM. The heat might make it fail. I guess how long you run the engine would determine your success.
Old 10-11-2014, 07:09:43 PM
Tom Weatherford Tom Weatherford is offline
Get a relief valve that you can set to 15 #. You will be good to go
Old 10-11-2014, 08:41:31 PM
The one I posted is set to 15.
Does the charging cylinder get that hot??.
I don't know much, we have not got our new toy home yet.
Thanks guys
---------- Post added at 07:41 PM ---------- Previous post was at 07:20 PM ----------
Temp is rated 0 to 250
My Youtube Channel
Old 10-11-2014, 09:44:27 PM
Side note.
Did anyone take over johns business for hot tube parts etc.
I hope they did
My Youtube Channel
Old 10-13-2014, 11:55:56 PM
Randy L Peterson Randy L Peterson is offline
I will be anxiously waiting to see Pictures.. The Anxiety may force to to go Fire mine up LOL..
Randy L Peterson
also Havin a Blast Preservin the Past
Old 10-14-2014, 07:43:56 AM
Randy.
It will be late November before anything happens.
Afain , is there any leads on hot tube stuff anymore or am I a few years too late?
My Youtube Channel
Old 10-14-2014, 02:05:17 PM
I haven't seen too much for Hot tube stuff as of Late.. My Reid has been SouthDakotaized.. It came to South Dakota in the 1960's and since hot tubes were not too popular around here someone converted it to Spark Plug and Buzz Coil.. Also Runs on a Tractor Carburator.. BUT It works and runs Good luck on the New Project
RLP
Reid intake valve Gasengin Oil Field Engines & Related Equipment 3 11-27-2014 01:01:10 PM
12hp Reid Valve Skidmore Oil Field Engines & Related Equipment 7 04-03-2011 11:18:27 PM
Reid 15hp Gas Valve cat.518 Oil Field Engines & Related Equipment 1 01-15-2011 07:16:11 PM
Setting Reid Valve Donald J Oil Field Engines & Related Equipment 1 06-25-2009 09:14:56 AM
15 hp Reid Blowoff valve Jim Gorter Oil Field Engines & Related Equipment 1 05-18-2006 05:29:27 AM
