Oil Field Engines
Reid's new home
this thread has 19 replies and has been viewed 3596 times
Old 07-06-2015, 07:48:35 PM
Tom Sampson's Avatar
Tom Sampson Tom Sampson is offline
Photo Reid's new home
Moved my 25hp Reid into our old chicken coop. I think it looks pretty good in there, what do you think? Click image for larger version
Tom Sampson
ohio
check out my engine videos at http://www.youtube.com/user/steamer123
The Following 4 Users Say Thank You to Tom Sampson For This Post:
Old 07-06-2015, 07:58:22 PM
Elden DuRand's Avatar
Default Re: Reid's new home
Uhh, Tom............
What do the chickens think about it. I'm sure the engine's happy, though.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 07-06-2015, 08:15:48 PM
Elden the chickens have been gone for years. lol
Tom Sampson
ohio
The Following User Says Thank You to Tom Sampson For This Post:
Old 07-07-2015, 07:07:02 AM
Peter Holmander Peter Holmander is offline
Smart use of the unused coop for a secondary shelter !!
The Following User Says Thank You to Peter Holmander For This Post:
Old 07-07-2015, 11:33:10 AM
Thumbs up Re: Reid's new home
If the roof is sound, you are OK, BUT - you will have yo protect any exposed iron from humidity in the air. Cosmoline, a light coating of oil based grease - NOT the soap complex based grease used in todays autos, it will wash off. Lube any working parts, including the pistons and cylinders liberally, and turn the engine over once a month.. Good luck with your new project.
Old 07-07-2015, 01:33:31 PM
Steve Kunz's Avatar
If it were mine I could not have put in the chicken coop.... If the chickens were gone for years I would have had it filled up with other stuff allready!!
Looks really good there!
Steve Kunz
The Following User Says Thank You to Steve Kunz For This Post:
Old 12-17-2015, 06:27:11 PM
Had to put some wheels under the Reid. I liked the looks of the skid but it was just to hard to pull out when I wanted to take it to shows.
This is it so far.
Next will be to find some steel wheels for it.
Tom Sampson
ohio
The Following 5 Users Say Thank You to Tom Sampson For This Post:
Old 12-21-2015, 07:53:49 PM
Here is a short video of it running today.
Tom Sampson
ohio
The Following 11 Users Say Thank You to Tom Sampson For This Post:
Old 12-21-2015, 08:24:31 PM
Glenn Ayers Glenn Ayers is offline
That's gotta be the sweetest runnin Reid I've ever seen !
Don't like the runnin gears under it though .... but sure makes life easier.
Kudos to the guy doing the "Tuning"
"I'll have the Red Pill, thank you."
The Following 2 Users Say Thank You to Glenn Ayers For This Post:
Old 12-21-2015, 08:29:13 PM
1911LY's Avatar
1911LY 1911LY is offline
Truthfully, I think it would look better at my place JK.
That think looks great. I have to stop looking at these Oil Field Engine post. You guys are a bad influence. Something tells me I'll have one if i find one I can afford.
The Following 2 Users Say Thank You to 1911LY For This Post:
Old 12-21-2015, 08:56:13 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Sweeeeeet! Wish I could get my 25 to run that nice.
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 02-04-2016, 04:40:17 PM
Dazzla Dazzla is offline
Certainly sounds a lot quieter than mine!
I'm running on the Wico mag at the moment, but it sounds like the timing is retarded. The best I can get it is firing at TDC. What sort of advance are you running with?
Dazzla
Old 02-04-2016, 08:44:13 PM
Dazzla not sure exactly but its just a few degrees before top dead center.
Tom Sampson
ohio
Old 02-05-2016, 10:16:03 AM
Cheers Tom
I guess I need to get into mine and see what I can do about advancing it a little.
I'll keep watching your clip for inspiration of how a 25 can run!
Dazzla
The Following 2 Users Say Thank You to Dazzla For This Post:
Old 02-05-2016, 03:55:05 PM
Lookin' good. I bet that rig bounces a bit on the pneumatic tires, if the speed gets up
Old 02-05-2016, 04:07:25 PM
It may bounce a little but these tires are actually foam filled so that should help a lot.
Tom Sampson
ohio
Old 02-05-2016, 05:38:37 PM
Amax Amax is offline
That is impressive.
The Following User Says Thank You to Amax For This Post:
Old 02-05-2016, 09:12:07 PM
David A. David A. is offline
that is really sweet sounding..................I WANT ONE! great job
The Following User Says Thank You to David A. For This Post:
Old 02-06-2016, 09:07:17 AM
engine nut engine nut is offline
Tom you need another chicken coop. then you can get another Reid : )
The Following User Says Thank You to engine nut For This Post:
Old 06-15-2016, 09:15:50 AM
Smokzalot Smokzalot is offline
That's a sweet runner! What type of oil should you use?
New Toy Followed me home 30 HP Reid Earnie Hampton Oil Field Engines & Related Equipment 4 08-09-2014 09:36:34 PM
Reid DC finally got it home wingnut13 Oil Field Engines & Related Equipment 0 08-02-2014 05:57:44 PM
12 h.p reid home mike jones Oil Field Engines & Related Equipment 2 11-04-2006 11:31:19 PM
Another Reid home Tom Schoolcraft Oil Field Engines & Related Equipment 5 08-24-2006 10:36:01 AM
Reid retirement home W.P.Klein Oil Field Engines & Related Equipment 1 06-01-2005 09:34:16 AM
