Oil Field Engines
Drips per minute, 20 hp Ball?
this thread has 6 replies and has been viewed 1567 times
Old 10-12-2015, 10:00:10 PM
Ron Shelton Ron Shelton is offline
Default Drips per minute, 20 hp Ball?
Hi all, I have a 20 hp Ball oilfield engine and the cross slide is obvious and the crank has chain oilers but when i think of that huge piston getting a tiny drop??? This engine will be running a cider mill and press but not working too hard, what should i set the oilers for the cylinder and crank?
Old 10-12-2015, 11:30:07 PM
Bob Whitney Bob Whitney is offline
Default Re: Drips per minut, 20 hp Ball ???
I don't believe in counting drips. These cylinders and pistons are large and require a lot of oil, the cylinders and rings are not at there best. You need that oil to seal the rings and cylinders. I use heavy oil and use about a quart in 5 hours of run time. I also have a water leak into the cylinder, makes for a real attention getter, for the first start up in the morning. Take 3 hits and belch 2 to 3 Qt of water out the 4 inch stack straight up. Yep, sometimes you get it, and sometimes you don't, forgot to check the wind.
Bob
Old 10-13-2015, 12:31:08 AM
Default Re: Drips per minut, 20 hp Ball?
Ha ha, wow I can only imagine! Sounds like it has it's own personality for sure I can only find non detergent oil in 30 weight and even that is getting hard to find but summed it up in saying 1 quart in 5 hours, Thanks Bob
Old 10-13-2015, 01:30:22 PM
What type of oiler does the engine use? If Powel-Boson, SAE 50 oil and 1 drop per inch of cylinder diameter bore per minute. If 8" cylinder bore - 8 drops/minute. 10" bore - 10 drops etc. SAE 30 is probably too thin for these big engine cylinders.
NAPA auto parts can get up to SAE 80 in non detergent oil - you have to ask for it. Cheaper to buy by the case too. They also have up to SAE 50 in detergent oils as well in these big 2 stroke engines, it won't matter which one you use as a cylinder oil. If your engine were a 4 stroke, I would not use a detergent oil in it.
If you get liquid oil out the exhaust, as the engine is running, you are probably getting enough oil. No oil - probably running a bit dry on oil. If you can get a look at the piston thru the exhaust port, it should appear wet with oil. If dry, add more oil!
Old 10-13-2015, 04:40:47 PM
con-rad con-rad is offline
Also,i believe that if the cylinder is over-oiled that can lead to coking in the cylinder that creates hot-spots that can cause pre-ignition (dieseling). So more isnt always better.
conrad
The Following User Says Thank You to con-rad For This Post:
Old 10-20-2015, 07:53:19 AM
bimjy bimjy is offline
Think grandson and I over oiled 9 hp oil city, worked engine a bit, it heated up and began over revving like it was going to "run away". Got it shut down. As I was cleaning britches Alex was asking WHAT JUST HAPPENED GRAMPA!!
Old 05-06-2017, 08:21:01 AM
mrxlh mrxlh is offline
Default Re: Drips per minute, 20 hp Ball?
The correct formula for power cylinder oil is HP*8*24/OEM Constant = PPD. The factory probably guessed or had some sort of verification method for drops. The richest 2 cycle OEM BHP/PPD is 4800, the leanest is 10000. So for your engine it would be 1 Pint per day at full load using the richest constant and .48 Pint per day using the leanest constant at full load.
---------- Post added at 07:17:58 AM ---------- Previous post was at 07:14:53 AM ----------
SO somehow I misread the HP to be 25, instead of 20. In any case it would be 20*8*24/4800 or 20*8*24/10000 which would be .08 PPD Rich, .38 PPD lean.
---------- Post added at 07:21:01 AM ---------- Previous post was at 07:17:58 AM ----------
If your going to stay with a drop feed richest would be 8 drops per minute, and leanest would be 3.8 drops per minute.
One Minute gas engine help Mike Shaffer Hit & Miss Gas Engine Discussion 7 04-29-2015 07:52:26 PM
A bad day/ or a BAD 1/2 minute Ihorse Hit & Miss Gas Engine Discussion 23 04-01-2013 09:58:55 PM
One Minute Engine Foseng Hit & Miss Gas Engine Discussion 7 08-19-2012 08:41:48 PM
5hp Bessemer: drips per minute rockinr Oil Field Engines & Related Equipment 4 08-22-2009 01:52:14 PM
3HP NOVO DRIPS GAS? George L. Antique Engine Archives 1 08-20-2003 06:49:15 PM
