Oil Field Engines
FM ZC 208 Dating My OFE
this thread has 5 replies and has been viewed 1124 times
Old 03-27-2016, 07:29:10 PM
ClayMartin ClayMartin is offline
Default FM ZC 208 Dating My OFE
I would like to know how I can date my engine. My serial # is K 520755. I am unable to find any specific manufacturing date. Any help in this matter would be greatly appreciated.
Old 03-27-2016, 07:48:56 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
Default Re: FM ZC 208 Dating My OFE
My list is showing 1922-1923.
Old 03-27-2016, 09:01:25 PM
Allan Wright Allan Wright is offline
I don't think there is anyway to date engines that begin with a K. These were post 1948 and that is as far as the serial number list goes. About all you can do is look for casting dates on different parts of your engine. A lot of the dates are on the block.
The Following User Says Thank You to Allan Wright For This Post:
Old 03-28-2016, 02:31:09 PM
Reed Engine's Avatar
I understand the K stood for Kansas City. What I was told once by a man who knew a lot.
Does the block have a round access hole in the rear or is it solid? The ones with the hole were the last ones made. The ones with the solid case dating before them had a oil sight glass on the rear and the ones before those had a dip stick in the lid and no sight glass on the rear.
Old 06-02-2016, 05:02:52 PM
Mike in NC's Avatar
Where can you find the serial number? Someone I know just bought a ZC 7-8 HP. I am trying to get it going for him. It needs some work but not a lot.
SmokStak Member #28
Old 06-02-2016, 06:31:10 PM
All I've ever seen are on the block itself above the governor cover (small round cover). The serials are visible even with the top cover on. Some of the last engines made by fm and bell had serials on a small square looking boss above the rear access cover. Again on the block and visible with the top cover on.
3 HP Jaeger dating Nate Bolduc Hit & Miss Gas Engine Discussion 1 05-26-2012 11:00:17 PM
Help dating plows JTT Horse Drawn Equipment 4 11-08-2009 09:20:25 PM
Help Dating OLDS 5A Oldsiron Hit & Miss Gas Engine Discussion 18 09-17-2008 04:39:56 PM
Need help dating a briggs oldenginenut Small Air Cooled Gasoline Engines 1 04-07-2008 11:14:03 PM
Dating an AKN bbunn1 Wisconsin Engines 2 10-09-2006 06:51:55 PM
