Oil Field Engines
Myrick Natural Gas Regulator
this thread has 6 replies and has been viewed 1249 times
Old 04-22-2016, 08:59:52 PM
Brian Lynch's Avatar
Default Myrick Natural Gas Regulator
I'm rehab-ing this 1910s-20s vintage Myrick regulator to put on my 1914 4 hp Eclipse type H. Most everything has come apart with a vengeance. As you can see, there were prior attempts made to free the valve chest nut. Somebody must have been given a new hammer and chisel for a birthday. That did come out after much preaching of the Heat & Kroil gospel. The only casualty to report is the valve link that hooks the diaphragm to the valve. It twisted off after about 2 hours of work. Looks like lathe & mill work are in the future for this. The valve seat is rusty from mouse piss, spiders and whatever else made it in there. It's a 45* seat so that's an easy one. I did find that what was left of the rubber diaphragm was not a formed one, but is flat. I've got that covered. The actual travel from valve off-seat to on-seat is only about 0.125". Some more glass beading, machine work & paint. The diaphragm tension spring and keepers were gone. Must have been a low gas pressure well.
ID:	252107   Click image for larger version
ID:	252108   Click image for larger version
ID:	252109   Click image for larger version
The Following User Says Thank You to Brian Lynch For This Post:
Old 04-22-2016, 09:07:31 PM
Default Re: Myrick nat. gas regulator
A few more pix to give perspective.
ID:	252112   Click image for larger version
ID:	252113   Click image for larger version
ID:	252114   Click image for larger version
The Following 5 Users Say Thank You to Brian Lynch For This Post:
Old 04-30-2016, 07:18:42 PM
The regulator is "sorta kinda" done. All the machined surfaces were touched up on a surface grinder and the valve seat was recut, lapped in and leak tested. It seems to work but hangs up once in a while. I need to get a few more ounces of spring pressure on the diaphragm & valve assembly. I had to guess at what the original pressure differential spring looked like. Since I'm running this against a primary regulator, a heavy spring isn't necessary to make it work. Here's my Question Do any of our fellow OAF's here have one of these apart? I'd like to know the length, wire diameter and number of coils in an original spring.
Old 05-02-2016, 04:29:40 PM
TomBall TomBall is offline
Brian, I tripped over one in my spare parts room and I thought of your post. I just tore it apart to see the spring. The wire diameter is .250. The length of the spring is about 2 11/16. The ID of coil is .750 with the OD around 1.265. Starting at the flat part of the spring, there are 7 1/4 turns. It is a fairly stout bugger. I'd hate to wind that one.
The Following User Says Thank You to TomBall For This Post:
Old 05-02-2016, 10:03:25 PM
Wow Tom, they must have the suspension springs out of old narrow gauge railroad boxcars for those! That is a very stout spring. Thank you for taking the time to tear into your regulator and get the dimensions. Now I know what to look for.
Old 05-03-2016, 09:32:51 AM
DieselAddicted DieselAddicted is offline
I have had both of mine apart and the spring is a good bit more stout than I expected it to be. Did you replace the diaphragm? If so what is the material mine is starting to seep.
Old 05-03-2016, 08:22:00 PM
Diesel, I had a square-ish chunk of rubberized canvas that was just a big enough to replicate the original. I bought a piece that was about 24" X 24" years ago and to be honest, can't remember where. I have seen several types at the McMaster - Carr website.
CCK Natural gas regulator mounting question Motorhead Onan Generators 3 02-27-2013 08:45:20 PM
Kohler natural gas regulator royvoss Kohler Generators 17 09-19-2011 07:16:10 PM
Myrick Gas Regulator FArmstrong Oil Field Engines & Related Equipment 8 03-08-2010 12:11:04 AM
Myrick fuel regulator Doug Waggonner Oil Field Engines & Related Equipment 5 08-14-2009 08:57:02 AM
Natural Gas Regulator Mike Cushway Hit & Miss Gas Engine Discussion 2 01-09-2007 02:33:14 PM
