Oil Field Engines
25HP Superior info
this thread has 6 replies and has been viewed 1676 times
Old 05-19-2016, 10:02:04 PM
iowasmkr iowasmkr is offline
Default 25HP Superior info
Couple questions about a 25hp superior. Wondering what the big ring is attached to crank near counter weights and also what does the rear threaded hole behind main cap on left side of engine oil? Thanks!!
Old 05-19-2016, 10:58:01 PM
Greg Mosley Greg Mosley is offline
Default Re: 25HP Superior info
An Oil Slinger for the connecting rod. The crank is drilled through the throw to the Rod Journal. Oil is dripped in the ring and by centrifugal force it is delivered to the Rod Bearing. Enuf Said.
Old 06-13-2016, 10:22:52 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
I sure would like to see some more pics of this 25 that has four main bolts on each cap. Rather, studs and nuts.
Old 06-14-2016, 07:57:59 AM
Peter Holmander Peter Holmander is offline
Leonard, my 25 HP Fairbanks Morse YH has two bolts on the caps too. Might have been something that was done for extra insurance to prevent a loose cap.
Old 06-14-2016, 09:10:16 AM
I see 4 bolts on that main bearing cap.
Old 06-14-2016, 09:18:53 AM
MSimons's Avatar
MSimons MSimons is offline
Card Sponsor
I see four studs and 8 nuts but no bolts
The Following User Says Thank You to MSimons For This Post:
Old 09-29-2016, 07:17:24 PM
tyrion's Avatar
tyrion tyrion is offline
Leonard I should have that Superior home in a month or so. I will post some more pics then.
25hp Superior JWithers Oil Field Engines & Related Equipment 6 03-08-2016 09:44:26 PM
25hp Superior Harold Price Oil Field Engines & Related Equipment 7 02-01-2011 01:38:35 PM
25hp Superior moparguy Oil Field Engines & Related Equipment 3 11-28-2010 05:23:47 PM
25hp Superior Tom Weatherford Oil Field Engines & Related Equipment 1 10-24-2010 10:15:29 PM
Superior 25hp fixer1952 Hit & Miss Gas Engine Discussion 10 07-28-2008 07:21:09 PM
