Oil Field Engines
IHC LB Flywheel
this thread has 3 replies and has been viewed 940 times
Old 06-14-2016, 10:48:41 PM
Donkeypull Donkeypull is offline
Default IHC LB Flywheel
The spring in handle on my flywheel broke the other day on my IHC LB engine. Is there or where do I begin removing the pin from the flywheel and replacing that broken spring. I have a new spring in hand.
Old 06-15-2016, 12:58:21 AM
Ironsides Ironsides is offline
Default Re: IHC LB Flywheel
Be very careful it is quite easy to break the thinner cast iron on the back pin mount.Liberal amounts of WD40 or similar---be very careful with heat also,Norm
Old 06-15-2016, 04:45:09 AM
Card Sponsor
Sometimes IHC didn't drill the hole all of the way thru on the LA/Lb FWs . Drill a small hole but big enough for a punch thru the wheel at the underside of the pin and drive it out. There's a small plug at the outside sometimes. Looks like a small flat freeze out plug. Rob
Old 06-15-2016, 12:05:10 PM
FarmallPaul FarmallPaul is offline
Donkeypull- ShopDogSam likes to cut the pin if the inside hole isn't drilled all the way thru. That's what I did, but then you have to replace the pin. Check it out:
https://www.youtube.com/watch?v=XiwuDFMPH9g
The Following User Says Thank You to FarmallPaul For This Post:
Stover KE,spoke flywheel,solid flywheel weight interchange Matthew Guy Clarke Hit & Miss Gas Engine Discussion 2 12-22-2012 04:14:11 PM
Help with Flywheel dms0115 Vintage Diesel and Oil Stationary Engines 6 05-01-2012 01:28:17 AM
Briggs WI Flywheel vs WMB Flywheel Zim Small Air Cooled Gasoline Engines 2 03-02-2011 12:47:48 AM
Flywheel David Fassett Antique Engine Archives 0 11-16-2002 07:09:54 PM
One flywheel or two? Norm S Antique Engine Archives 5 11-02-2002 02:05:10 AM
