Oil Field Engines
Myrick 4 hp
this thread has 3 replies and has been viewed 913 times
Old 08-16-2016, 12:03:36 AM
Dale Carnahan Dale Carnahan is offline
Default Myrick 4 hp
Did the myrick H 4hp have a grease cup or a drip oiler on the fan? Mine has a grease cup. I just saw one with a drip oiler.Which one is right or both?
Old 08-16-2016, 04:50:47 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Default Re: Myrick 4 hp
Period photos show a grease cup....if the grease I'd too thick and the belt is loose, the fans tend to run slow. I believe this may be why some use oilers. OTO, an oiler will allow you to run longer unattended... I've used both but tend towards the grease cups.
ID:	260376   Click image for larger version
The Following 3 Users Say Thank You to PaulGray For This Post:
Old 08-16-2016, 09:10:43 AM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Grease cup on mine.
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
The Following User Says Thank You to Preston Wells For This Post:
Old 08-16-2016, 05:40:30 PM
Brian Lynch's Avatar
Oilers are way too messy. Oil spray comes off the fan and gets all over anything or anybody near it. Grease cup is miles ahead better.
The Following 2 Users Say Thank You to Brian Lynch For This Post:
Myrick 4 hp Dale Carnahan Oil Field Engines & Related Equipment 1 07-30-2016 08:59:03 PM
Myrick Jr? Mike Shaffer Hit & Miss Gas Engine Discussion 3 01-19-2015 12:33:22 AM
Myrick 4hp turnwaldw Oil Field Engines & Related Equipment 17 11-27-2013 03:31:03 PM
Myrick jr Janet Mohney Hit & Miss Gas Engine Discussion 4 04-15-2013 12:08:21 PM
Myrick fun Tom Sampson Hit & Miss Gas Engine Discussion 5 10-25-2009 11:54:08 PM
