Oil Field Engines
Finally got the Norton power home!
this thread has 7 replies and has been viewed 1509 times
Old 08-25-2016, 09:27:55 PM
Default Finally got the Norton power home!
If any of you remember, this project started last summer and turned into the most challenging retrieval I have ever done - and I expected it to be one of the easiest! The main shaft of the power extended deep into the concrete and would not budge. I suspect that due to the small footprint of the base there was a plate attached to the bottom of the shaft and the cement was poured around it for stability. I posted previous pics of the jackhammer operation to bust up the concrete. Had to wait for things to dry out to access it again. we went in with 2 cordless sawsalls and 4 batteries. It took quite a while but we were able to cut the 4" shaft off about 14 inches below the base. She is finally at home on display with the others of its ilk. Bill Klein
Name:	Norton power base 7.31.16.jpg
ID:	261207   Click image for larger version
Name:	Norton power crown wheel 7.31.16.jpg
ID:	261208   Click image for larger version
Name:	Fetchings 7.31.16.jpg
ID:	261209   Click image for larger version
The Following 10 Users Say Thank You to W.P.Klein For This Post:
Old 08-26-2016, 03:58:40 PM
Brian Lynch's Avatar
Default Re: Finally got the Norton power home!
Bill,
Is that a Clark & Norton or just Norton power? Does it say Wellsville on it?
Old 08-26-2016, 09:18:11 PM
Hi Brian. It just says Norton (no Clark). Does say Wellsville. Tell me what you're thinking.
Bill Klein
Old 08-29-2016, 04:27:40 PM
hillwomp hillwomp is offline
Hi Im looking for a air head pump jack any idea where to find one also looking for some double throw off hooks thanks
Old 09-01-2016, 09:56:44 PM
Bill Klein
Egg on my face Brian! I cleaned some caked mud/grease off the base last Sunday & there was "CLARK" ! So it is a Clark & Norton after all.
Bill Klein
---------- Post added at 09:56:44 PM ---------- Previous post was at 09:55:08 PM ----------
Sent you an e mail. Reply to it for some possible sources. Bill Klein
Old 09-02-2016, 06:42:09 AM
Hey Bill,
How far away from Wellsville did this power land? It's gotta be a record- most of these landed locally. Maybe 40 - 50 miles away tops.
Old 09-02-2016, 02:41:40 PM
KyleBlankenship's Avatar
KyleBlankenship KyleBlankenship is offline
that would match my clark and Norton engine!
Old 09-18-2016, 09:06:35 PM
Originally Posted by Brian Lynch View Post
Hey Bill,
It was in the woods near the little burg of Kosuth - about 12 miles east of Clarion Pa. Bill
The Following User Says Thank You to W.P.Klein For This Post:
Very stubborn Norton power! W.P.Klein Oil Field Engines & Related Equipment 3 12-22-2015 07:12:03 PM
help on Norton eccentric power W.P.Klein Oil Field Engines & Related Equipment 3 09-21-2015 09:43:15 PM
New toy is now home... finally Ackman Hit & Miss Gas Engine Discussion 4 06-02-2012 05:56:54 PM
Finally home... Jim Sherman Hit & Miss Gas Engine Discussion 16 09-21-2008 08:45:29 PM
It's finally home! Mike Monnier Antique Engine Archives 0 11-30-2004 06:02:32 PM
