Oil Field Engines
Halfbreed Hog Trough
this thread has 12 replies and has been viewed 2865 times
Old 09-06-2016, 09:14:18 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Default Halfbreed Hog Trough
Starting on one of my many Halfbreed projects. This one is a small Bessemer. I'm a Reid man don't know if I can get it to run on not.
ID:	262177   Click image for larger version
Skidmore aka engine hoarder
The Following 8 Users Say Thank You to Skidmore For This Post:
Old 09-07-2016, 12:42:57 PM
David A. David A. is offline
Default Re: Halfbreed Hog Trough
I am betting on you, good luck
Old 09-07-2016, 09:48:17 PM
Skidmore's Avatar
Thanks David. I got right into it this weekend. Not stuck it's loose real loose. Mains and crosshead need poured. Clutch side of crank has some wear.
ID:	262357   Click image for larger version
The Following User Says Thank You to Skidmore For This Post:
Old 09-09-2016, 06:42:18 AM
Early Iron Early Iron is offline
I have a F/T bed that needs new Babbitt at the mains. I'm planning it for October. Mine look about the same
Old 09-09-2016, 08:34:55 PM
Skidmore's Avatar
Photo Re: Halfbreed Hog Trough
Getting ready to pour the mains. Didn't worry about the wear on the crank. There will just be more babbit in that area. Leveled the bedplate to the shaft and centered the throw. One of the main caps had been brazed back together at one time. But it had cracked again. I was lucky to find a matching pair here on Harry's..
Name:	Farrar & Trefts  Babbit 001.jpg
ID:	262485   Click image for larger version
Name:	Brian Lynch F&T cap.jpg
ID:	262487   Click image for larger version
Old 09-19-2016, 10:25:55 PM
Skidmore's Avatar
Poured the crosshead and the main caps nice and thick should run for another 100+ years.
Name:	bessmer crosshead.png
ID:	263388   Click image for larger version
Old 09-20-2016, 04:07:45 PM
Brian Lynch's Avatar
Looks good. I'm pouring the same mains and crosshead in my F&T bed this coming weekend.
Old 09-23-2016, 12:53:42 AM
Skidmore's Avatar
Flywheel and clutch Key removal made easy. Drill it and tape it , screw in a grade 8 bolt with a spacer and pull it in tight. Also a hammer and a little heat is needed.
ID:	263589   Click image for larger version
ID:	263590   Click image for larger version
Old 12-09-2016, 09:48:49 PM
Skidmore's Avatar
Had this little halfbreed running. It's a Bessemer, hard to start. Takes very little fuel and a cold hot tube to start .Now it's water tank plumbing and skid building time. We always use the old time pipe fittings, getting hard to find. Picked up this nice riveted tank at Cool Springs this year. A little closer.
ID:	269928   Click image for larger version
The Following 4 Users Say Thank You to Skidmore For This Post:
Old 12-10-2016, 04:25:01 PM
lookin good, I like the ladder type truss u using for skid,I also found a riveted tank for my fb 15
The Following 2 Users Say Thank You to David A. For This Post:
Old 01-03-2017, 10:24:40 PM
Skidmore's Avatar
Starting to put the bells and whistles on Bessy.
ID:	271706   Click image for larger version
Name:	100_4982 (2)_LI.jpg
The Following 6 Users Say Thank You to Skidmore For This Post:
Old 01-03-2017, 11:05:32 PM
Lookin' sharp! Bill Klein
The Following User Says Thank You to W.P.Klein For This Post:
Old 01-08-2017, 12:58:19 PM
Skidmore's Avatar
It took me longer to upload this video than it did to pour the crosshead. https://youtu.be/tdjX9HujbII
Oil trough/ Oil well main bearings Jebaroni Hit & Miss Gas Engine Discussion 7 10-08-2015 04:43:00 PM
Looking for a trough for a mud pump, see picture. Jim Ritenour Hit & Miss Gas Engine Discussion 7 09-21-2013 08:11:39 PM
halfbreed HELP please Brickman Oil Field Engines & Related Equipment 13 10-24-2012 08:29:49 PM
Halfbreed Oil city Clayton Oil Field Engines & Related Equipment 9 09-08-2012 11:45:01 PM
Is this some type of halfbreed? Jeff and Maria Smith Oil Field Engines & Related Equipment 7 04-21-2009 05:31:39 PM
