Oil Field Engines
15 pattin saved
this thread has 12 replies and has been viewed 2285 times
Old 10-16-2016, 10:48:15 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Default 15 pattin saved
Passed weekend went to pick up a 15 hp pattin for my local club in Brookville Indiana. Took the some local Ofes to bring it home. We wanted to save building but time was not on our side. So we took it's frame and headed home on the four hour drive. Ever one made it home home safe.
Do i really look like a people person?
The Following 12 Users Say Thank You to Tom Geier For This Post:
Old 10-17-2016, 07:14:16 AM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Re: 15 pattin saved
Nice save! I fetched one long time ago. wished I would have kept it. it ended up going to western PA eastern OH I think. good luck with your engine and keep us posted
The Following 2 Users Say Thank You to Firewoodguy For This Post:
Old 10-17-2016, 04:20:41 PM
Thumbs up Re: 15 pattin saved
Hope you took pictures before you tore the remains down. It helps you to be able to see what it may have looked like. Did you get the power or well driveee with it? Good luck with your new project.
Old 10-17-2016, 06:06:39 PM
Tom Geier's Avatar
Tin was to tin on building to save. But got frame
The Following 4 Users Say Thank You to Tom Geier For This Post:
Old 10-17-2016, 06:11:20 PM
Tom Geier's Avatar
Guy wanted an extra $1000 for the wheel. It would have been to much hauling.
Old 10-19-2016, 06:14:14 PM
Too bad about the wheel. Hope it does not end up rotted out or as firewood.. let us know how you make out with the engine!
Old 10-20-2016, 08:23:12 PM
sounds like a lot of money for that wheel. Keep in touch with the gent, you might be able to get it. As of now, it's just a wheel without power? The guy should have given it to ya! As Andrew said, it just might end up as firewood!
Old 10-24-2016, 09:27:37 PM
con-rad con-rad is offline
I just picked up a 15 Pattin myself! It's my second oilfield engine. It's in good shape and shouldn't take too much to get running.
Connor
The Following User Says Thank You to con-rad For This Post:
Old 10-27-2016, 07:01:33 PM
Tom Geier's Avatar
Was that on Craigslist
Old 10-27-2016, 07:27:27 PM
Yes it was.
Old 10-29-2016, 08:01:44 PM
Tom Geier's Avatar
Well at club grounds and next is the building.
The Following User Says Thank You to Tom Geier For This Post:
Old 10-30-2016, 09:33:55 AM
CBarth66 CBarth66 is offline
I always wanted to own a Pattin, as they were built in my hometown of Marietta Ohio. My SM Jones engine has the same kind of pendulum governor. I do know of one or two here in the area still back in the woods pumping oil. I pass by the building where they were built on occasions. My father in law worked at Pattin manufacturing when they made mine bolts to stabilize the mine walls. They finally closed about 25 years ago. The building is now a contractors supply business.
The Following 2 Users Say Thank You to CBarth66 For This Post:
Old 11-25-2016, 12:10:54 AM
Skidmore's Avatar
Skidmore Skidmore is offline
Are you fellas sure you have 15hp engines 60" flywheels? All the 15hp I've seen have a bedplate like a Reid the front is curved not flat, https://www.smokstak.com/forum/showthread.php?t=76352
Skidmore aka engine hoarder
15 Pattin Chris Austin Oil Field Engines & Related Equipment 10 06-25-2014 12:12:33 PM
8 HP Pattin Greg Shipley Oil Field Engines & Related Equipment 17 04-09-2011 03:46:48 PM
12 HP Pattin. Greg Shipley Oil Field Engines & Related Equipment 5 05-08-2008 09:07:13 PM
12 Hp Pattin Lawrence Lindsey Oil Field Engines & Related Equipment 5 06-14-2007 11:23:14 PM
Looking for Pattin parts Greg Shipley Oil Field Engines & Related Equipment 0 02-24-2006 11:14:05 AM
