Oil Field Engines
Huge 8 Cylinder Crankshaft With 10 Main Bearings Laying In The Weeds?
this thread has 21 replies and has been viewed 3036 times
Old 01-30-2017, 10:40:26 PM
Turbo's Avatar
Turbo Turbo is offline
Default Re: Huge 8 Cylinder Crankshaft With 10 Main Bearings Laying In The Weeds?
I don't see this problem with the new evolution series GE's. They have a very different engine design compared to the old FDL's. The EVO's use two separate connecting rods on a common journal and a separate cylinder and head arrangement. The FDL's use a master and art rod arrangement which I think is a little weak. And it is a headless cylinder design. Which means if something foreign gets on top of the piston something has to give. Usually the PA!! I have not seen any air tank failures, But I have heard stories from the old boys!! Some of the older switchers that come in are almost 50 years old so I can imagine the air tanks might be a little thin in spots. I try to give them a wide berth too!!
Old 01-31-2017, 01:43:47 PM
Rick Trotnic Rick Trotnic is offline
Originally Posted by Tony Thompson View Post
Hello all,
I spend most of my time in the antique tractor section or on Lugs & Cleats, but I found something new to take pictures of.
Was out on a fun run and found this 30 foot long crankshaft laying in the weeds of a salvage yard. I can not help but wonder what it could be for, so I am posting it here to see if anyone would know.
It is about 30 feet long, has 8 rod journals, 10 main journals and uses a fairly short stroke for such a big unit.
Any ideas
Tony
It's a Worthington from a power house. Was located in the city of Erie Kansas and ran a large generator. I'm looking for the ID tag. I have pictures of the complete engine somewhere.
The Following 8 Users Say Thank You to Rick Trotnic For This Post:
Fairbanks Morse T Main Bearings Craig Barton Hit & Miss Gas Engine Discussion 4 04-02-2017 08:02:30 AM
46 JD A, Is it okay to use used main bearings? SlantdashA Antique Farm Tractors 8 11-21-2012 01:40:02 PM
Can anyone identify this huge Crankshaft Counterweight? Wendell Kelch Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 07-21-2007 07:35:04 AM
main bearings 6hpMarty Antique Engine Archives 2 08-31-2004 12:21:55 AM
main rod bearings Warren Hall Antique Engine Archives 5 03-28-2000 09:44:56 PM
