Oil Field Engines
Ohio Oil Co. Oilfield engines
this thread has 7 replies and has been viewed 1412 times
Old 02-12-2017, 11:27:41 AM
tyrion's Avatar
tyrion tyrion is offline
Default Ohio Oil Co. Oilfield engines
Anybody have any info on oilfield engines made for the Ohio Oil Co?
I looked at one a few weeks ago and it looks a lot like a Superior oilfield 4 stroke engine. (wish I had taken a picture)
The one I looked at was a 25 hp. I believe and while it looked like a Superior there were some differences pointed out to me.
Flywheels were heavier, Main bearing caps split parallel to the bedplate instead of at a 45 angle like a Superior, and most components have a part# that starts with an X.
I was told that some parts would fit a Superior engine and you could tell that it was a Ohio oil part because it would have that part # that had the X prefix.
Anybody ever heard of or seen one of these?
The Following User Says Thank You to tyrion For This Post:
Old 02-12-2017, 12:11:57 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Default Re: Ohio Oil Co. Oilfield engines
Call Bob Wyatt. 618 838 7945
Do i really look like a people person?
The Following User Says Thank You to Tom Geier For This Post:
Old 02-12-2017, 12:30:56 PM
Bob Willman Bob Willman is offline
Ohio Oil Company headquartered in Findlay, Ohio - now Marathon - did a lot of business with Superior engines. To what extent I do not know.
Bob
WB8NQW
The Following User Says Thank You to Bob Willman For This Post:
Old 02-12-2017, 03:08:38 PM
Dirk Hochstetler Dirk Hochstetler is offline
I've got a 20hp that the front clean out cover is cast with Ohio oil on it.
The Following 2 Users Say Thank You to Dirk Hochstetler For This Post:
Old 02-13-2017, 11:32:24 PM
Tom Geier's Avatar
No Ohio oil. But another company that used superior
The Following 3 Users Say Thank You to Tom Geier For This Post:
Old 02-14-2017, 12:38:55 AM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
This one belongs to a buddy of mine. It's a 25hp Ohio built Superior. The main caps sure are different from the typical Superiors. I think everything else would probably interchange.
ID:	274915   Click image for larger version
ID:	274916   Click image for larger version
The Following 2 Users Say Thank You to Leonard Fausset For This Post:
Old 02-14-2017, 01:01:35 PM
tyrion's Avatar
Yes that's it! Thanks for posting that Leonard. Friend of ours in Flat Rock, ILL has one like it.
The way I get it Ohio Oil Co. owned a foundry at Bridgeport, ILL. and they built these Superior clones there and also most if not all repair parts for Superiors that they had in service in the area. It is believed that they were not marketed but just used by Ohio Oil on their leases. That would explain why there is next to no info on these engines floating around. I am going to head down to that area tomorrow, so I will try to get more info if I can and maybe a picture or two. Randall
---------- Post added at 12:01:35 PM ---------- Previous post was at 11:57:03 AM ----------
Thanks Tom that is an interesting article, and thanks for the info on Bob just a super nice fellow! Randall
Old 02-14-2017, 02:52:05 PM
JWithers JWithers is offline
Here is a 25hp with the flat caps and ported exhaust. This engine lives in Crosby, ND
https://youtu.be/OhpPek-VENY
Jeremy Withers
The Following 5 Users Say Thank You to JWithers For This Post:
We Want to See Your Oilfield Engines Jonah Close Oil Field Engines & Related Equipment 39 04-20-2014 11:46:01 PM
New guy with oilfield engines Avery22x36 Oil Field Engines & Related Equipment 12 02-25-2014 05:33:51 PM
Oilfield engines in OZ LizRon Smokstak Down Under 0 05-20-2013 04:31:15 AM
Ohio Made Gas Engines / Plain City, Ohio 2013 Mark Thompson Hit & Miss Gas Engine Discussion 0 08-15-2012 06:47:35 PM
Oilfield Engine Society featured at Plain City, Ohio Mark Thompson Hit & Miss Gas Engine Discussion 2 12-10-2008 02:38:41 PM
