Oil Field Engines
Hot Tube Info Needed
this thread has 9 replies and has been viewed 1600 times
Old 03-30-2017, 05:16:01 PM
LeroyB LeroyB is offline
Default Hot Tube Info Needed
I am working on a Struthers Wells halfbreed that had hot tube ignition. Are there any plans out there for making the hot tube? It is gone except for a short nipple coming out of the head I think it should be similar to the one shown below.
Old 03-30-2017, 06:35:37 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Default Re: Hot Tube Info Needed
What is the NPT of the hole you want to put a hot tube into. I made this hot tube assembly. But changed it to a myrick an used a horizontal hot tube. If you need help making a burner. Let me know.
ID:	278863   Click image for larger version
Do i really look like a people person?
The Following 2 Users Say Thank You to Tom Geier For This Post:
Old 03-31-2017, 07:49:11 AM
The hole is 1/2 NPT
Old 03-31-2017, 09:48:04 AM
PaulGray's Avatar
PaulGray PaulGray is offline
The important thing is to have a long enough hot tube so that when the engine comes up to compression, it is able to force the mixture into the heated area. If you get it set up, have the tube hot, and she refuses to fire..., chances are the tube may be too short for the extra plumbing with the elbow and such.
The Following User Says Thank You to PaulGray For This Post:
Old 03-31-2017, 01:43:08 PM
Tom Geier's Avatar
Could you hook up a micro switch and use a spark plug
Old 03-31-2017, 01:48:12 PM
I could but would like to put a hot tube on it
Old 04-01-2017, 08:52:54 AM
justme7917 justme7917 is offline
i would use sec 80 pipe fittings it is trying to hold back a explosion
The Following User Says Thank You to justme7917 For This Post:
Old 04-07-2017, 02:12:00 PM
here are pics of the ports on the cylinder
ID:	279507   Click image for larger version
Old 04-23-2017, 02:34:43 PM
John Burns used to make hot tubes out of stainless steel, with a 1/4" IPS base. You can bush down 1/2" to 1/4" easily. Not sure if John still has any left, but he might be able to point you in the right direction.
Old 04-24-2017, 10:31:10 AM
Luke Wagner Luke Wagner is offline
i have hot tubes for sale 1/4 x 6" 30.00 ea
Thanks Luke 717-497-1680
The Following 2 Users Say Thank You to Luke Wagner For This Post:
Myrick Eclipse 4 HP Air Cooled Hot Tube Hit & Miss Manual Needed Tom Gosciminski Hit & Miss Gas Engine Discussion 14 12-15-2015 09:46:10 PM
Hot tube burner help needed Greg Johnson Oil Field Engines & Related Equipment 4 09-15-2010 05:25:21 PM
Hot tube parts needed. Greg Shipley Oil Field Engines & Related Equipment 4 01-05-2006 01:04:05 AM
Hot Tube Info. Needed Joe LeBlanc Antique Engine Archives 5 01-07-2003 04:12:40 PM
Novo Tube cooled info needed Norm Antique Engine Archives 1 11-19-2000 11:06:10 PM
