Oil Field Engines
Ring end gap spacing?
this thread has 11 replies and has been viewed 2250 times
Old 05-12-2017, 10:02:59 PM
con-rad con-rad is offline
Default Ring end gap spacing?
Hey all,
I've searched to no avail the formula used to determine the ring end gap needed when installing new rings. This is for my 15HP Pattin with a 9" bore.
Thanks!
connor
Old 05-12-2017, 10:15:16 PM
Default Re: Ring end gap spacing?
I use .004" per inch of bore minimum, .036" on your engine, more doesn't hurt, you don't want the ends to meet when hot.
Old 05-13-2017, 10:37:16 AM
Thank you!
Connor
Old 05-13-2017, 08:58:11 PM
cherob cherob is offline
Over the years I have used Wiseco pistons in a variety of small engines. They recommend .004" per inch of diameter for the top ring and .005 per inch on all the others for general use. On high performance racing engines they recommend .007" and .0075"
Old 05-13-2017, 10:57:46 PM
Foseng Foseng is offline
This is the Hepolite piston / piston ring information chart I have The ring gaps are at the bottom. Repeats what people are saying but interesting chart as it also relates to piston clearances. It was being used as a bookmark in old marine engine book I bought.
Dave
Laoag City
Philippines
The Following 3 Users Say Thank You to Foseng For This Post:
Old 05-14-2017, 06:09:20 AM
Elden DuRand's Avatar
Dave:
The chart is not copyable. I'd really like to print it out for hanging on the wall of my shop.
Is there any way you could include it in a post as a copyable .JPG?
Thanks!
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 05-14-2017, 06:50:09 AM
Right clock copy/paste. The image size is 11x14.
Old 05-14-2017, 06:58:50 AM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
http://i306.photobucket.com/albums/n...Piston1Red.jpg
restoring old iron, hot air engines and modelmaker.
The Following User Says Thank You to Marv in Minn For This Post:
Old 05-14-2017, 06:30:53 PM
I got it! Thanks!
[SIGPIC][/SIGPIC]
Take care - Elden
Old 05-14-2017, 08:09:15 PM
bear67 bear67 is offline
I know I am the computer dummy here, but I tried several ways to save this where I could print it and failed each and every one. Computer said could not open this file. Any help appreciated. I don't have a teenage grand kid here to "persplain" this to Papa.
Old 05-15-2017, 05:36:02 AM
Bear:
I couldn't copy the original image in post 5 but Marv posted a direct link to it in post 8 that I could copy to a file and print.
[SIGPIC][/SIGPIC]
Take care - Elden
Old 05-15-2017, 07:15:34 PM
Reed Engine's Avatar
Nice chart.
Sattley Cam to Crankshaft spacing Nick Lingg Hit & Miss Gas Engine Discussion 4 08-11-2013 08:30:09 AM
Mounting hole spacing Lauson RSH Mac Leod Small Air Cooled Gasoline Engines 3 08-09-2008 10:44:52 AM
Ring Gap Spacing -- 15.0 JC pcbye Onan Generators 2 08-06-2007 10:10:57 PM
Tecumseh Magnet Spacing landlockedmarine Small Air Cooled Gasoline Engines 7 12-31-2004 06:19:09 PM
Piston Ring Spacing Keith Smigle Antique Engine Archives 5 11-04-2002 12:38:18 PM
