Oil Field Engines
Myrick Eclipse hot tube
this thread has 5 replies and has been viewed 1405 times
Old 06-18-2017, 07:41:46 PM
Nate Bolduc Nate Bolduc is offline
Default Myrick Eclipse hot tube
I recently picked up a 4HP Myrick Eclipse engine project. I have a reproduction hot tube, chimney and burner for it. When I was a coolspring, I was looking at the Myricks there and they don't have this strange boss on the head like mine has. I looks to be original and there is carbon inside it. I didn't try to remove it. Is there something I'm missing?
Old 06-18-2017, 10:37:20 PM
Default Re: Myrick Eclipse hot tube
I am pretty sure that bushing is not original. It looks like someone made it to fit a chimney from another engine.
Old 06-19-2017, 05:56:14 AM
It has silver paint on it. Thats why I thought it was original. I guess it is easy enough to turn down on the lathe to fit the chimney.
Old 06-19-2017, 11:05:38 AM
You can tell that it not original because it is not pitted like the head is and the nuts on the head are not original either, they should be flat on the bottom with a .01" to .015" washer like step turned into the bottom of the nut.
The Following 2 Users Say Thank You to Bill Hazzard For This Post:
Old 06-19-2017, 08:58:23 PM
Thanks Bill. I'll turn it down and make it work.
Old 06-20-2017, 08:16:27 PM
PaulGray's Avatar
PaulGray PaulGray is offline
The spud for the hot tube is 1/2 NPT where it goes in the head and is like ~2" long. The hot tube is 1/4 NPT, screws into the spud and the hot tube slips over the spud and is affixed with a set screw. Yours looks like one used on an ARACO I have seen.
The Following User Says Thank You to PaulGray For This Post:
Myrick Eclipse 4 HP Air Cooled Hot Tube Hit & Miss Manual Needed Tom Gosciminski Hit & Miss Gas Engine Discussion 14 12-15-2015 09:46:10 PM
Myrick Eclipse burner tube length Jonah Close Oil Field Engines & Related Equipment 1 03-28-2013 09:50:06 AM
Myrick eclipse hot tube chimney part number? Jonah Close Oil Field Engines & Related Equipment 1 12-25-2012 07:08:17 PM
Myrick Eclipse 4 HP value$? Jonah Close Oil Field Engines & Related Equipment 1 10-11-2012 09:06:45 AM
4hp Myrick Eclipse Adam Hartz Hit & Miss Gas Engine Discussion 1 09-22-2010 04:13:23 PM
