Oil Field Engines
Witte 98RBA output pully wanted
this thread has 16 replies and has been viewed 1614 times
Old 08-13-2017, 01:35:19 PM
Twharley Twharley is offline
Default Witte 98RBA output pully wanted
Witte 98rba
hello I just acquired a witte 98rba everything is there except the main output crankshaft pulley or flywheel, to power the alternator and fan, if there is a picture of the pulley or a spare that may be laying around, this unit has electric start and charge system and frame, looks to be nat. gas or propane got it for 500.00 in a barn 1/2 mile from my house would make a nice generator if done I found a manual on line for a 98 engine but little info otherwise hope I can get it in service all help is appreciated. thanks
Old 08-13-2017, 03:00:44 PM
Reed Engine's Avatar
Default Re: witte 98rba output pully wanted
Not familiar with that exact matter model but am somewhat with the 98 RC. It did not have a generator or the pully you describe. A picture might be helpful. In my mind I wonder if the extras might have been added on after the fact?
Old 08-13-2017, 09:29:07 PM
from what I understand the 98rba was a witte stock production unit 5.6k output, I will have to get some pictures posted I suspect the pulley would have to be the size if the flywheel of course v grooved because the smaller alternator pulley is about 10 or more inches in diameter.
Old 08-14-2017, 07:45:56 PM
I take it this is a gen set of some kind?
Old 08-15-2017, 12:05:30 PM
Default Re: Witte 98RBA output pully wanted
I'm trying to figure how upload pictures jpeg of this genset
---------- Post added at 11:05:30 AM ---------- Previous post was at 10:47:02 AM ----------
again the model number is witte 98RBA serial number is 44563 Has 5.6k Alternator, still trying to figure how to upload jpg pictures, Has electric start, Electronic ignition, Murphy switch shutoff system, Charge system, just need fan side grooved flywheel
Old 08-15-2017, 08:29:01 PM
It may need to be made. Arrow bought Witte from National Oliwell quite a few years ago. Before NO became Varco. Arrow has let most of the parts dwindle to nothing. If I see what it is you need I might be able to either find something or make one. I'm sure others near you could do the same.
Old 08-16-2017, 08:20:51 AM
Thank you, I suspect from looking at other pictures of gen sets, that the pulley would be a modified flywheel with groves the same diameter as the right side flywheel I will try to get some pictures uploaded and crankshaft output diameter and flywheel diameter . Thanks again.
Old 08-18-2017, 07:04:34 AM
Still trying to figure out how to upload pictures, anyway the flywheel starter side measures 20 inches across and the diameter is 2.00 . and the output shaft diameter is 1.934 has a damaged wood drift key, that might explain what happened to the flywheel pulley, the keyway is very repairable. the output shaft stub is guessing about 3 inches long, any Ideas, looking to have one made as long as I don't have to mortgage my house?? Thanks
Old 08-18-2017, 01:18:18 PM
So, there's no power take on the engine?
Old 08-18-2017, 09:14:01 PM
tyrion's Avatar
tyrion tyrion is offline
David Johnson is the fellow who can tell you for a fact what you have and what parts you may need. He may even give you some names to help find used parts.
Like Ed I am familiar w/ the Witte 98 RC. Standing behind the engine the left side has the flywheel....on the RC it's just a flywheel no pulley no v belt grooves nothing. On the right side you would see a clutch system with a multi groove v belt output pulley, a second pulley on the engine side of the clutch ran the condenser fan (cooling fan).
If you just need a pulley to run the fan and alternator and I assume both of these items drive from the right side of the engine. just buy a QD pulley about 10" dia with a bushing that fits the 1.94 output shaft.
The Following User Says Thank You to tyrion For This Post:
Old 08-19-2017, 11:12:47 AM
there is no power take off on the fan side of the motor, just a 2in OD. by 4in long keyway. crankshaft stub, flywheel side has a 20 inch electric start toothed flywheel with folding crank handle in flywheel
Old 08-19-2017, 09:07:48 PM
Then I would think a sheave or pulley of whatever diameter you choose would fit right on the 2" shaft. You would use whatever series QD bushing to adapt it on. These are redily available.
Old 08-21-2017, 07:25:37 PM
well if I use the 20 inch flywheel 20 X 1200rpm =13.33inch serpentine gen head pulley with 2 in bore anybody got one??????? the one I have is inly 6 inch v belt.
Old 08-22-2017, 08:40:02 PM
QD sheaves come in various series, SD, SF, E for example. You find the size od sheave you want, an example would be a 20" 2B (has two B section grooves). It will be from a series, SF possibly. You would use a SF 2" hub or bushing to adapt the sheave to the shaft. Done.
Old 08-23-2017, 04:41:39 PM
Here's an example. This is a 20" 3C sheave on an E 2 1/4" bushing.
Old 08-24-2017, 07:51:25 PM
is it for sale? with a 2 in bushing
Old 09-12-2017, 11:38:17 AM
Hello I just want to thank everyone for their input, I got very lucky, I went back to the area that I got the witte from, and found the pulley, and then later found a complete gasket set, and rings, rod bearings, all bushings to overhaul the engine, a starter a nos electronic ignition with housing and pickup, belt guards, 3 sets of belts, a extra head complete, a set of valves, tappets, murphy oil shutoff,, engine runs fine after setting valves, the only problem I have is that the governor does not work at all, any ideas on that??? again Thanks To Everyone.. TW.
Witte Clutch Parts Wanted IWL BCNU Hit & Miss Gas Engine Discussion 3 06-16-2019 07:54:34 PM
6hp Witte info wanted IWL BCNU Hit & Miss Gas Engine Discussion 5 09-20-2014 10:22:05 PM
Witte 2 HP Date wanted lister d Hit & Miss Gas Engine Discussion 6 01-20-2014 07:15:57 PM
Witte 2HP help wanted lister d Hit & Miss Gas Engine Discussion 7 04-04-2009 08:06:57 PM
witte info wanted scott vassar Antique Engine Archives 2 08-14-2001 07:32:46 AM
