Oil Field Engines
12 HP Pattin 4 Stroke
this thread has 21 replies and has been viewed 3589 times
Old 08-23-2017, 08:03:11 PM
tyrion's Avatar
tyrion tyrion is offline
Default 12 HP Pattin 4 Stroke
Anybody out there know what a 12 hp Pattin will weigh? This one is a 4 stroke with the flyball governor and is set up for a wico PR mag. Has the wood shoe clutch, and countershaft w/ eccentric. The bed plate has the bearings for the counter shaft as an integral casting.
Old 08-23-2017, 10:22:03 PM
con-rad con-rad is offline
Default Re: 12 HP Pattin 4 stroke
My 15HP two stroke is about 4500Lbs. Not your engine, but close enough to help you get a ballpark.
connor
The Following User Says Thank You to con-rad For This Post:
Old 08-24-2017, 05:52:14 AM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
I might have it in one of my catalogs at home. I am in portland. I still need to pull one off the well still near marietta Ohio
Do i really look like a people person?
Old 08-24-2017, 06:25:49 PM
tyrion's Avatar
Thanks in advance Tom! Have a great time at Portland, wish I could be there.
Old 08-29-2017, 09:36:44 PM
tyrion's Avatar
Photo Re: 12 HP Pattin 4 stroke
Got a rain day from work so I went and collected my Pattin 12hp. Went pretty well after we extracted a 3" oak that had grown up between the flywheel and the bed plate. This engine has been in this location for about 15 yrs. I was amazed that after removing the oak the engine was free!
ID:	289821   Click image for larger version
ID:	289822   Click image for larger version
ID:	289823   Click image for larger version
The Following 4 Users Say Thank You to tyrion For This Post:
Old 08-29-2017, 11:49:59 PM
Ahh, that'll make a fine play toy!
The Following User Says Thank You to Kirk Taylor For This Post:
Old 08-30-2017, 06:58:52 AM
Peter Holmander Peter Holmander is offline
Looks like that tin can held up well too. That helped keep rain water out of it.
Old 08-30-2017, 06:29:38 PM
tyrion's Avatar
Yep the fellow I got it from said he would replace the can every year or so... guess he did!
Old 09-04-2017, 05:10:16 AM
tyrion's Avatar
Got the Pattin home. Went to work with pb blaster and got most everything freed up. Most parts look good, so far.
Items that I know need attention: big end rod bearing
cyl. water jacket is cracked
So now I will begin taking it apart cleaning and looking for more items that need attention.
ID:	290313   Click image for larger version
ID:	290314   Click image for larger version
ID:	290315   Click image for larger version
The Following User Says Thank You to tyrion For This Post:
Old 10-08-2017, 09:59:37 PM
tyrion's Avatar
Got the tear down finished, getting the piston out was NOT EASY! but its out
ID:	293168   Click image for larger version
ID:	293169   Click image for larger version
ID:	293170   Click image for larger version
The Following 2 Users Say Thank You to tyrion For This Post:
Old 10-08-2017, 10:15:28 PM
tyrion's Avatar
A few more pics. Got the skid finished and the engine on it, then I piss anted it into the shop.
Now it's time to get to work!
ID:	293172   Click image for larger version
ID:	293173   Click image for larger version
ID:	293174   Click image for larger version
The Following 5 Users Say Thank You to tyrion For This Post:
Old 10-13-2017, 08:27:59 PM
tyrion's Avatar
Been getting a little work done. Got the rings off and cleaned up the piston and ring grooves. Honed the cylinder, looks like it has set for awhile with water in the bottom front of the cyl. pitted pretty bad and it is in a bad place for compression. valve box and valves were in really good shape though, seats in good shape, guides fine, ex valve looks like new, so I just give the valves a good lapping and called it done.
Cyl. water jacket has had a issue with hard water at some point. side of the cyl. had a crack about 16" long and the bottom had a big crack starting at the head going back thru the water tapping and on back about another 12" this was the worst one as it was 1/8" wide in places. I cleaned them up v them out and filled them with epoxy.
Con rod bearing was a little loose, but the bearing and crank journal looked good so I set the cap up in the mill and took .015 off and snugged it up pretty good.
I have put it back together and been plumbing it up for a start up. Video coming if it runs
ID:	293473   Click image for larger version
ID:	293474   Click image for larger version
ID:	293475   Click image for larger version
The Following 3 Users Say Thank You to tyrion For This Post:
Old 10-30-2017, 07:53:26 AM
tyrion's Avatar
I have just about finished work on the Pattin, here's a short video of how easy it starts
---------- Post added at 07:53:26 AM ---------- Previous post was at 07:40:09 AM ----------
This is another little video of the Pattin running with enough load to keep from latching out.
Old 10-30-2017, 09:14:31 AM
Default Re: 12 HP Pattin 4 Stroke
Nice Job !! She runs nice. I like your starting setup. Especially the kill switch on your starting lever. I want to install a starting aid on my 15 HP Reid but I don't trust the flywheels on them. They are not as beefy as some of the oilfield engines. Many tell me they would be fine but I don't feel comfy with that method. Last thing I want is a busted flywheel. Going to mount a large flat belt pulley on the sisterville clutch mounting side of the flywheel and spin her over with a flat belt driven by a 2 cyl Wisconsin motor.
Old 10-30-2017, 09:22:34 AM
tyrion's Avatar
I bet that will work just fine! When it's easy to start them they get started more often.
Old 10-30-2017, 10:01:07 AM
I agree. I read somewhere where its best to have a 6 to 1 ratio on the pulleys so I have a 36 inch pulley that will be driven by a 6 inch one. Plan on leaving the belt loose so it just slides on the pulley surface, and then have a 3rd pulley mounted on a pivot to tighten the belt slack and get her turning. I saw something similar done on another engine and it worked nicely. I wish you were closer to Cincinnati OH. My daughter lives near there and when I go to visit her, I get bored after a few days. If you were closer, I'd visit you and see your engine up close
Old 10-30-2017, 12:55:43 PM
Very nice!!
I am curious as to why the cylinder exhaust port is plugged.
Old 10-30-2017, 03:46:29 PM
tyrion's Avatar
It runs better that way.
Old 01-28-2018, 12:59:17 AM
Joe Anderson Joe Anderson is offline
Sorry for the late answer but I haven't been on here for a while. The weight of a 12 hp ekonomy is 3,500 pounds.
Old 01-28-2018, 10:15:28 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Nice job looks and runs great. How did you repair the crack in the cylinder water jacket ? Have any picture of the crack repair process ?
Skidmore aka engine hoarder
15 Pattin Chris Austin Oil Field Engines & Related Equipment 10 06-25-2014 12:12:33 PM
8 HP Pattin Greg Shipley Oil Field Engines & Related Equipment 17 04-09-2011 03:46:48 PM
12 HP Pattin. Greg Shipley Oil Field Engines & Related Equipment 5 05-08-2008 09:07:13 PM
12 Hp Pattin Lawrence Lindsey Oil Field Engines & Related Equipment 5 06-14-2007 11:23:14 PM
12 Hp Pattin 4 cycle Pix tom weatherford Antique Engine Archives 0 03-12-2003 07:03:52 PM
