Oil Field Engines
Reid Valve Box Sealing
this thread has 2 replies and has been viewed 1235 times
Old 09-26-2017, 01:52:06 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
Default Reid Valve Box Sealing
I recently purchased a Left hand 20 hp . I pulled the valve box or cylinder it is from the main casting. It is nice and clean, but where someone in time past taking it apart drove a chisel into the gasket and into the lower sealing ring.
I would guess that what it seals would be the charging cylinder pressure and intake. So if it leaks a bit it may not affect the running. Any opinions ?
Options would be to weld it up and machine it down, maybe just machine it clean and make a spacer gasket ?
The crank appears bent a bit too.
Old 09-27-2017, 09:14:31 AM
Ellis Wellman Ellis Wellman is offline
Default Re: Reid valve box sealing
Try repairing the gouge with JB weld.Clean off the area,assemble with gasket ring.I did it on a 12 hp.
The Following User Says Thank You to Ellis Wellman For This Post:
Old 10-04-2017, 08:43:10 AM
Joel Sanderson Joel Sanderson is offline
Default Re: Reid Valve Box Sealing
I turned my valve's steps in the lathe. You'll need to turn both steps though, so the outer and inner seals seat together. Measure your block and make sure the steps on the valve match it.
My inner seal is made of 1/8" brass channel (or is it 9/64ths?) butt soldered (soft) with the opening on the outside and filled with 1/8" graphite packing, which compresses outwards against the block. The outer, lower seal is an O-ring, which compresses easier than the brass. Like you said, it only needs to contain the charge--not the cylinder pressure. This gives the brass a better chance to seal. This combination has been running almost daily for over ten years, under pretty heavy load.
My guess is the O-ring will seal the wound just fine for you. It's not under as much pressure as the upper seal. It stays cool too, so JB weld should work too, like Mr. Wellman suggested, but be sure to degrease it well.
Bent cranks and run-out in the flywheels are pretty common, I think. I've got a lot of wobble on my drive-side flywheel, but it was machined that way. Bent cranks are kind of a weakness of Reids. Even the manual talks about it, cautioning against throwing the reversing clutch back too fast. Still, 119 years later, it's still making a living, so I can't complain.
Hope this helped.
Joel
The Following 2 Users Say Thank You to Joel Sanderson For This Post:
Reid safety valve. Maybe NOT! Sekiar Oil Field Engines & Related Equipment 4 06-29-2015 07:54:59 AM
Reid popoff valve Dustin D Ehli Oil Field Engines & Related Equipment 7 10-14-2014 02:05:17 PM
Reid 15hp Gas Valve cat.518 Oil Field Engines & Related Equipment 1 01-15-2011 07:16:11 PM
HELP On Reid Main valve Don Unkefer Oil Field Engines & Related Equipment 6 02-19-2010 07:42:04 PM
Setting Reid Valve Donald J Oil Field Engines & Related Equipment 1 06-25-2009 09:14:56 AM
