Oil Field Engines
Franklin Valveless Information Needed and Pictures
this thread has 6 replies and has been viewed 1557 times
Old 09-26-2017, 06:28:40 PM
abowman89 abowman89 is offline
Default Franklin Valveless Information Needed and Pictures
I've found a complete and loose franklin valveless 25hp engine I really want to buy, but I have some questions. Anybody have a ball park gross weight on this thing? It's ultimately getting mounted to a trailer. Next thing, has anybody ever seen a 25hp set up with airstart? This would be my first oilfield engine, I've been looking for one for awhile.
Old 09-26-2017, 07:03:41 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
Default Re: Ok franklin valveless information needed and pictures.
I just weighed a 20 hp Reid I had in 3 pieces. If I added right it was right at 5,000 #. But its not a Franklin . But you can't go lite buying an oil field engine. Go for it.
Old 09-26-2017, 09:20:21 PM
tyrion's Avatar
tyrion tyrion is offline
Default Re: Franklin Valveless Information Needed and Pictures
The 25 hp Franklin I used to have weighed about 7000# I believe that Franklin had an air start feature available but mine didn't have the feature. My Franklin had the lay shaft does yours?
Old 09-27-2017, 06:09:34 AM
KevinJ KevinJ is offline
I think the 40 at our club is about 15,000#
1950 Farmall M, 1962 Farmall 560D, Kubota GL3940HSTC, Kubota B7500, Kubota BX1860, many implements, etc.
Old 09-27-2017, 12:44:22 PM
I don't have any specific data for Franklin engines, but here is the Bessemer dimension sheet. This may give you an idea of the weight of your engine. Franklins, I think, tend to be a little more meaty than Bessemers. I would guess your Franklin to weigh 7000 - 7300 lbs. if it's open-crank (it may have a tin cover but not a closed cast iron crankcase). That weight does not include the clutch pulley.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 10-05-2017, 04:31:43 PM
After talk to the gentleman with the engine he seems to think it's somewhere between 2500 and 3000 lbs. it's got 66in diameter flywheels, is 10ft long, and 4ft wide. It has the tin cover over the cranks case. No clutch
---------- Post added at 03:31:43 PM ---------- Previous post was at 03:30:40 PM ----------
That sounds light to me......
Old 10-05-2017, 08:36:53 PM
Dustin D Ehli Dustin D Ehli is offline
I think he is off by about 4000 pounds
Having a blast preserving the past.
My Youtube Channel
Franklin Valveless 25 hp Gary Bahre Hit & Miss Gas Engine Discussion 2 11-18-2014 07:47:38 PM
Franklin Valveless 20 hp info needed Stockpile5 Oil Field Engines & Related Equipment 1 09-25-2011 10:04:27 PM
25 H.P. Franklin Valveless Fred Van Hook Oil Field Engines & Related Equipment 0 09-02-2007 09:17:06 PM
franklin valveless 25 hp tim rostar Antique Engine Archives 0 10-28-2003 06:38:57 PM
15 HP Franklin valveless info needed. Ed Stewart Antique Engine Archives 1 05-28-2000 10:08:09 AM
